Oh Boy!!! Do I have a Story to tell!!!!
Guess I'll start from the beginning....
Hubby was changing out stock brake pads to Hawk's ceramic pads..Until I did a walk around... To check and clean/wipe down our C7 LT3 Coupe after his diy job.
We did take the extra option in the Sport Performance $$$$$ and is also (Non Z51).
Well I went to clean exhaust tips and noticed what looked to me "Rust" on the Mufflers, and misalignment of exhaust pipes..showed Hubby and was baffled and concern, knowing we only had 1,200 miles on the C7.
Well Hubby took the C7 back to the Dealership where purchased and had the service dept. look over. Service guy adjusted mufflers to level out as straight as he could get them and stated that it "Was the way that the pipes were welded" and cleaned the mufflers with wheel brite and suggested to paint mufflers with a High Temp. Spray Paint...
I've posted a few pictures to view.. of before and after...Hubby has decided to take to another Dealership for a second look over..
There's 4 adjustable muffler bolts viewable in pictures. How hard would it be to put a straight edge, loosen and adjust?
Heidi
Heidi
Relax, everything is OK...enjoy driving.
One good burnout will fix it.
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
Heidi
Heidi
Not perfect but worked for me. Some have also covered the area with stainless steel baffles.
The tip alignment has also been noted and some have had the mufflers clamps loosened and realigned with some Improvement.
This is nothing unusual and has been reported here numerous times in the past. A filler plate will nicely hide the surface slag rust, and a careful adjustment will get the tips close to straight. How I did it is in post 10 here:
http://forums.corvetteforum.com/c7-g...-not-even.html
People are funny at how **** they are.
Just call the dealer and tell them your muffler bearings are rusty and you want them replaced under warranty.
I am sure they will be more than happy to help.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Serious OCD issues for the OP.
It's a friggin car. Drive it and enjoy it.
Or, you can install a perforated stainless steel exhaust filler panel made by American Car Craft like I did. It covers the empty space (and "rust") and also looks good.
Its insignificant.
