[Z06] Well...heads are coming off....
#42
Could be moisture absorbent material from a Desiccant pack. Perhaps someone stored the car and placed a few packs in and around the engine to prevent corrosion during storage. The bag could have torn and dropped a few pellets down there. Would be my guess over rat poison.
#43
The heads were recieved by RPM on Monday afternoon. Im hoping to hear.from Charlie.asap about the overall condition of the wearable parts. Ill post up the results...or maybe Charlie.can if there is lots to discuss.
#45
I just finished pulling my heads yesterday. I had planned to run ARP studs, but I'm not so sure about that now. I don't think there is enough clearance to get the heads over the studs while in the car. Anyone know for sure if there's enough clearance or not???
Hey trpblk....those blue things look suspiciously similar to them little blue pecker pills. You wouldn't be having relations with your motor would you?
#46
#47
I just had my heads redone by RPM. All 16 valve guides were replaced. Many of the guides were worn so bad they were outside of the range of the measuring device he uses to measure them. My car was bone stock with 33k miles. I do track the car and it has seen about 30 events.
#48
The Consigliere
Received 5,447 Likes
#49
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Your a smart man for pulling the heads , was just a matter of time b/f your stock LS7 engine would have popped!
#51
Update...I talked briefly w Charlie @ RPM today, the heads are disassembled and the news is as we would have thought thus far....things are NOT perfect. Ill post up info as it comes.
#54
Check tjwong's experience with arp bolts coming loose/needing a re-torque.
http://forums.corvetteforum.com/c6-t...post1579638483
#55
I was expecting bad news. I had my fresh LSX heads redone by richard at wcch. They were run for just minutes on my 454. They had egg shaped wear on the guides. I was truly disappointed to hear for so little run time.
#56
On another note, I would like to thank the OP for this topic, it's sealed the deal for me to have work done on my heads before they have any issues, I have an 07 (built 07/2006) with 11k miles, I don't expect to see a great deal of wear but an ounce of prevention is worth it's weight in gold.
#57
Most things do. We have pages of re-torques on helicopters after we service or tear down and rebuild one. Never understood why you don't see this in the auto world as much. Guess the industry thinks people would complain.
Obviously aircraft are subject to different maintenance procedures. I don't think any cars have key nuts safety wired either.
I mention this for the OP's information - he may want to follow up and see about putting some loc-tite on the head bolts as the factory bolts have.
#58
You had your heads reworked by WCCH, then run on the dyno briefly. Afterwards, you pulled the heads, and found egg shaped wear on the guides already? Were they stock sintered iron guides, or were they replacements?
If this is true, this is the first reported issue with redone heads, I believe, and it puts a serious kink in the theory that the heads/guides are the root cause!!!
#59
Just to be clear...
Were the heads checked by a different shop after the dyno run, or did WCCH's do both the before-and-after evaluation?
#60
Of the millions of cars on the road, to my knowledge, none require checking head bolt torque as part of normal maintenance or even a 15,000 mile check up.
Aircraft don't use lock tight on anything so we have to use lock nuts, castllated nuts, and of course safety wire..
