[Z06] Is CAGS skip shift eliminator still needed on a Z06?
I installed it on my C5... its been so long ago, I forget why it was needed in the first place... wasnt it that the computer locked you out of 1st gear for slow starts or something making you start in 2nd gear?
Is this still a problem with the Z06?
One-to-Four Shift Light
When this light comes on, you can only shift from FIRST (1) to FOURTH (4) instead of FIRST (1) to SECOND (2).
You must complete the shift into FOURTH (4) to turn off this feature.
This helps you get the best possible fuel economy.
After shifting to FOURTH (4), you may downshift to a lower gear if you prefer.
Notice: Forcing the shift lever into any gear except FOURTH (4) when the 1 TO 4 SHIFT light comes on may damage the transmission.
Shift only from FIRST (1) to FOURTH (4) when the light comes on.
This light will come on when:
• The engine coolant temperature is higher than 169°F (76°C),
• the vehicle is going 15 to 19 mph (24 to 31 km/h) and
• the vehicle 21 percent throttle or less.
They are the same for every tranny ever built with it. I have an 09 Z, and it was more intrusive than my 08 LS3 was - not sure why. I put on the CAGS eliminator - I really hate it when it kicks in.
St. Jude Donor '08-'09-'10-'11-'12
I, too, had it on my C5 and I was prepared to put it on this Z06. After I got it I have not found a need for it. The CAGS programming seems to be much less aggressive than it was on my C5. Anyway, I have only seen the light once in almost a year. So for me, it hasn't even been an issue.
You've got to be kidding. Is this a labor day April fools joke. The ECM looks for the skip shift solenoid's(or other) 2.2k load resistance. Adding more series resistance, is just like removing the fuse. Of course you know this, but it's still pretty funny.
The solenoid is actually 24 ohms, not 2.2K. The combined series load about 2.4K ohms so the ECM sees only 5mA and thinks everything is still ok. But it's not enough current to energize the solenoid.
The fuse is still in the circuit and will definitely blow if you attempt to draw more than 10A.
DH
When the conditions are met my shifter sticks and won't go anywhere, but back into first. I didn't want to take it to the dealer so I bought a CAGS bypass. I just need to find a way to jack up the rear of my car to get it installed.
Wil Cooksey #256
Adding more series resistance is exactly that; you still have a circuit. The ECM is not looking for a specific resistance, it's looking for current load when power is applied.
Same here! I don't currently have a jack either so here's how I installed mine. While backing out of my driveway I allowed the rear driver wheel to mount the ascending curb and parked it there. The 6" curb allowed me enough clearance to shimmy under from the rear of the car and install the bypass. Hope this helps.
The guy at West Coast Corvettess suggested your idea, but I've got a common driveway with my neighbor and we have trees at each side of the driveways. I guess I'll have to check out some of my friends' driveways.
Here's my 2 cents worth - since I have the same question.
I bought a new 2008 z06 only 4 weeks ago.
I have deliberately tried to make it skip shift by trying to make sure all 3of the conditions are met. I know for sure I was between 15 and 19 mph, and I know the coolant was above 169 degrees. I don't know the %throttle. I can consistently shift from 1st to 2nd under these conditions as I accelerate slowly from 16 to 18 mph or decelerate slowly from 18 to 16 mph.
No skip shift. I'll use CAGS elimination if I need it, but I'm not convinced I need it.
Before buying the z06, I test drove a used 05 c6 and did have the skip shift experience, so I know what to expect.
Does the z06 transmission gearing make it hard to meet the skip shift criteria?
http://www.xse.com/leres/z06/cags.html
CAGS is one of those things that can be difficult to demonstrate on command. Here's a recipe that should help:
- Bring the car up to temperature and find a safe area
- Come to a complete stop
- Launch with constant and minimal throttle
- Wait for 15 MPH and the "1 4" instrument cluster indicator
CF Senior Member
BTW, there's now an express solution with no soldering:Here's how it works. Go out to your local chain parts store and pick up a two-pack of Littelfuse Smart Fuses. Take one out, blow it and then install it in the fuseblock. Complete details are available on my CAGS page. There's also a discussion here: The CAGS LED Fuse.
