"Single" A-pillar gauge pod
Does this exist for a C6? Really dont want a bulky double/triple pod. Not really committed on drilled into the dash either at this point.
Thanks.
Thanks.
I went with this option. Has suction cups to attach to the windshield. The power cord i wont need for my aeroforcetech Interceptor guage.
http://autometer.com/cat_accessoriesdetail.aspx?vid=186
I'll let you know how it works out. The D-Pic guages are standard 2 1/16 so it should work out. I'll post pics when I get it in.
Got it in, haven't really figured out where I want it exactly yet, but this is pretty close. But I have to play around with it a bit before I install the wiring through. But I think you get the idea, should work great.
That's not a speaker it's a mic for the nav and on-star and all you have to do is buy one from GM to fill the hole.
No reason I can think of why you couldn't. There is a block that holds the suction cup as well as holding the housing together with two screws. You could attach velcro to that and mount it someplace I suppose. But there are tons of other pods out there with no suction cups.
Here's what my friend did for a single gauge pod. Pretty slick install if I do say so myself.
http://forums.corvetteforum.com/c6-t...dashboard.html
