Engine Ground Map?
St. Jude Donor '09
Engine Ground Map?
Does anyone have a map of the engine grounds. I still have the SCS error and I have been informed that it could be a loose engine ground.
Any help appreciated.
how are the volts doing? If the car is charging and you have a message only call Tracy at RevExtreme a forum vendor. He has a modded alt that might be the trick. Otherwise welcome to my hell with this too.
Hope this helps
Check out this earlier thread:
http://forums.corvetteforum.com/show....php?t=1974842
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
Working in conjunction with that excellent ground map, use this to see exactly what is tied into those ground connections:
http://www.ls2.com/forums/showthread...hreadid=648556
Elmer
Elmer
