C6 wiring diagrams or ground locations?
Anybody have any? If not, are there any common grounds that have issues on these cars? I have had a couple of odd glitches here and there and wanted to check/clean all the grounds and see if there are any common grounding issues with the C6 like the C5 has. I already cleaned the ones on the top of both frame rails behind the headlights. Any others? Thanks.
Joe
Joe
Popular Reply
03-22-2008, 12:54 PM
I've found what appear to be 12 total in the service manual.
There are 6 in the Engine compartment labelled with a "G" in the list.
(1) Battery Positive Voltage
(2) Fuse Block-Underhood C4
(3) Fuse Block-Underhood C3
(4) Fuse Block-Underhood C2
(5) Fuse Block-Underhood C1
(6) Battery
(7) Fuse Block-Underhood
(8) G104
(9) G106 (Engine Block)
(10) G107 (Engine Block)
(11) G105 (Engine Block)
(12) G101
(13) G102
There are 2 on the drivers side
(1) Cigar Lighter
(2) Auxiliary Outlet
(3) G301
(4) G201
(5) Splice Pack SP205
(6) Ignition Mode Switch
2 on the passenger side
(1) Splice Pack SP208
(2) Body Control Module (BCM) C2
(3) Body Control Module (BCM) C3
(4) Body Control Module (BCM) C4
(5) G202
(6) Relay Block-I/P
(7) G302
2 at the rear suspension:
(1) Fuel Tank-Right
(2) G402
(3) G401
(6) Battery
(8) G104
(12) G101
(13) G102
(1) Cigar Lighter
(3) G301
(4) G201
(5) G202
(6) Relay Block-I/P
(7) G302
(1) Fuel Tank-Right
(2) G402
(3) G401
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
There are 7 total, as far as I can tell. One more near the battery, 2 in the "passenger area", and 2 more behind the rear axle. These are usually pretty trouble free, unlike the C-5s that had the multi-pin connector at each ground.
Thank you! I just want to give them a once over to rule them out. The two on top of the frame rails that I did clean were still painted over, they didn't even clean the stud down to bare metal before bolting the terminals down! There were a couple little spots of metal showing and that's it.
Tntfroitz (09-29-2020)
Do you know where the ones in the passenger area are? I want to check mine too.
Attachment 48164492
(6) Battery
(8) G104
(12) G101
(13) G102
Attachment 48164493
(1) Cigar Lighter
(3) G301
(4) G201
(5) G202
(6) Relay Block-I/P
(7) G302
Attachment 48164494
(1) Fuel Tank-Right
(2) G402
(3) G401
Attachment 48164495
Attachment 48164492
(6) Battery
(8) G104
(12) G101
(13) G102
Attachment 48164493
(1) Cigar Lighter
(3) G301
(4) G201
(5) G202
(6) Relay Block-I/P
(7) G302
Attachment 48164494
(1) Fuel Tank-Right
(2) G402
(3) G401
Attachment 48164495
The following 13 users liked this post by talon90:
AraNe (03-14-2024),
dr_gallup (08-30-2016),
Layzee (05-27-2021),
Mike98SilVert (06-03-2022),
Movie Muscle (05-05-2017),
and 8 others liked this post.
I have a pdf that shows the ground locations and includes schematics. This was a dealer only pdf that came out at the introduction of the C6. I dont know if it would be of any interest nowdays but if someone knows how to send an 11 meg file and is interested....
I'd be very interested, but I don't know how to send an 11 meg file lol.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,837 Likes
2015 C7 of the Year Finalist
Working in conjunction with that excellent ground map, use this to see exactly what is tied into those ground connections:
http://www.ls2.com/forums/showthread...hreadid=648556
Elmer
Elmer
(6) Battery
(8) G104
(12) G101
(13) G102
(1) Cigar Lighter
(3) G301
(4) G201
(5) G202
(6) Relay Block-I/P
(7) G302
(1) Fuel Tank-Right
(2) G402
(3) G401
(6) Battery
(8) G104
(12) G101
(13) G102
(1) Cigar Lighter
(3) G301
(4) G201
(5) G202
(6) Relay Block-I/P
(7) G302
(1) Fuel Tank-Right
(2) G402
(3) G401
Um... I think I found 13? I pulled my info from a 2007 Helms.
2007 C6 Corvette Grounds
Ground points and what they control:
G101
G102
G104, G303, G108
G105, G107
G201
G202 1 of 2
G202 2 of 2
G301
G302, G401, G402
On 2nd thought, 12. One is for convertible OR one is for Coupe
Ok, we're good on 12. Pick the car type and you use a different G spot!
G101
G102
G104, G303, G108
G105, G107
G201
G202 1 of 2
G202 2 of 2
G301
G302, G401, G402
MadDogZ06 (01-10-2021)
G101
G102
G104, G303, G108
G105, G107
G201
G202 1 of 2
G202 2 of 2
G301
G302, G401, G402
G101
G102
G104, G303, G108
G105, G107
G201
G202 1 of 2
G202 2 of 2
G301
G302, G401, G402
I know this is an old thread, but great info. Crabman, if you still have the mentioned PDF, I can walk you through sending it to me. Thank you.
