My car is to loud, HELP!!
I've sifted through some of the exhaust threads, but didnt really find what I need. My car has Lg longtubes with GHL catback. After I had the cam etc installed it seemed to be even louder than before, now with aggravating drone. Outside, the car sounds wicked, but inside is just to loud to really enjoy the radio,cell etc, not to mention that I have to shut the car off at ANY type of drive through ( Burger King, bank). Back before the cam, I tried the B&B bullets, WAY LOUD, and I had the B&B route66 back before the headers. But I dont remember much about those. Advice please for those with the same or similar setup. Thanks!!
http://store.summitracing.com/egnsea...2&autoview=sku
St. Jude Donor '08-'09-'10
Zo6 Catbacks
From what i understand those who have the drone from headers + catbacks etc solved their drone problem by installing a stock ZO6 catback system with no loss of power. I have borla stingers and have a little drone around 1400-1600 rpm. I dont mind it but dont know if ill be able to say the same when I install LG LT'S next week ??
Yea I had the same problem with my C5 when I went h/c with Borla Stingers. Neat for a car cruise but annoying to daily drive. Couldn't have a conversation in the car and my neighbors were glad when that car was stolen. Matter of fact exhaust woke me up and I got on the phone so fast to the cops they gave chase but couldn't catch it.
Here's the solution I went with on my C6. Stock mufflers for daily driving (love it, quiet as a mouse) and these for when I want to make some noise. And let me tell you, with a G5x3 these things roar when open.
Here's my write up and details.
http://forums.corvetteforum.com/show....php?t=1628234
The coupe with the glass over the exhaust acts like an amphitheater for the noise.
I toned it down somewhat---that's relative to the ear/hearing.. with:
1. the roll of silencer butyl with aluminum backing....had to use 2 layers. pulled the carpet in the back up to install
2. also the aluminum plate above the mufflers got a coat of it too. the underneath of the car. I was afraid it would melt but it hasn't so far.
3. In addition to that I used a mat 1/2" thick type material with foam and butyl in it. Under the carpet as well.
All my labor........materials about $250.
What really helped the most is the 4.10's. It put the cruising rpm's at 2000+, no drone there.
Thanks!
I love the G5x3. But I wouldn't do it without putting in thinner cometic gaskets to keep low end up. Only costs a couple of hundred extra.
Here's that write up if you are interested with sound clips and dyno sheets.
http://forums.corvetteforum.com/show....php?t=1769681
I agree on the gear swap. It is a wonderful side benefit that the 4.10's boost the engine speed at cruise just enough to get above the annoying frequencies. The difference is dramatic, positive and noticeable. However, the result still may not be what you are looking for.
You can try Corsa's. I have them and even with heads, cam, headers, no cats, etc. there is no drone inside the cabin. Also the cam really changes the sound of corsa's... guys often ask if I have b&b, etc as the cam changes the typical motor-boat corsa idle.
I'm gonna go ahead and trade a member my GHL for his B&B Route66. Hopefully it will be the "Volume" I'm looking for. I've installed all of my previous catbacks as well as headers, but I'm catching heck removing this one. Those "slip fit" pipes arnt wanting to let go!! Maybe a light tap with a rubber mallet will help. I'll let yall know the outcome once the B&B's are installed.
I thought the portion that differentiated the route 66 from the bullets was in the area where your x-pipe is now? If that's the case I'm not sure you can run them with headers. I may be wrong but double check first!
