[Z06] Callaway Honker or Vararam??
Thanks.
The Consigliere
Received 5,458 Likes
Ran a Halltech on my Z. Great set-up.
Have a Callaway on my Callaway GS; seems to work well.
Between those two...I would go with the Calloway. Don't believe in the 'ram air' stuff, but both will give you fresh air.
I have the KillerB.
I have the KillerB.
Jlang1 (06-16-2020)
_"SCOTT"_
VARARAM........no brainer.
Thread from 2008:
http://forums.corvetteforum.com/c6-t...ch-intake.html
Enjoy the read!
#33
rammin it
Car is definitely faster, but not because of the intake. I had the Vararam as my very first mod. Then added headers and cam. When I did the heads/cam, I changed to the Callaway because it kept getting really hot (235+ degrees) in the summer months, the higher compression no doubt taking it over the top. There was minimal change in "feel" because we're only talking 5-10rwhp difference, and when you're running 550+ rwhp, you aren't going to feel much on street tires. The Callaway dropped the summer coolant temps more than 20 degrees on average. Now I rarely see it over 210 even with spirited driving. Average is around 190-200.
#34
#35
Former Vendor
We've had a lot of success with the Corsa CF air-intake and the Halltech units. Both make great power with the stock throttle body. We usually lean towards the Halltech for the NW102 TB's though.
Good luck with your decision!
-Shane
-Shane
