[Z06] 10.71 130.32 -- New Record Pass by Bone-Stock C6 Z06 on Drag Radials
#101
Wouldn't there be no tire spin then if the clutch was not clamping properly on the shifts?
Ron
#102
I agree with everything you've said John. BUT, regarding point #9, have you seen proof of this theory in any logs? I've only had 2 passes logged ever, so I know minimal about them and reading them, but wouldn't you see RPM spikes (or rises) at or immediately after the shifts if the clutch was clamping less, or if there was a delay in the clutch lock-up?
Ron
Ron
I've learned a lot by studying in-car video showing driver, feet and intruments (tach and speedo). Camcorder recording 60 frames/second.
Keep in mind that on each shift the clutch must reconcile the difference between pre-shift and post-shift rpm. And it slips between the hit and lock-up. When the clutch is hotter, it slips more while negotiating the lock-up.
BTW, the in-car video has more data resolution that the typical data logger. That's especially the case when the PCM is busy with other tasks.
Ranger
#103
Ron,
Ranger
Ranger
Any time I tried to launch over 4,500 rpms on my Mickey Thompson DR's, the clutch fell to the floor. I have not yet tried a launch over 4,500 rpm's on the Hoosiers. I likely WILL next time at the track just to see the results.
I have been using 4,400-4,500 rpms at launch. John,you are now up to 4,000rpm's at launch. So what launch rpm do you think heats the clutch too much then? We are basically 400 rpms apart now launching since you switched to the Hoosiers, and yet you've improved your MPH & ET.
Ron
#104
Ive noticed with the stock clutch it tends to heat up quickly. At my last track day ran a total of 3 times. with a 4500 rpm launch my 60fts were as follows: 1.59 then a 1.56. I tried launching at 4800 rpms, it caught me off guard just how hard the car lauched. I was late on the throttle squeeze and ended up bogging a bit but still managed to cut a 1.60 ft. What i noticed best for me to avoid the infamous clutch pedal to the floor, i make sure to do the following.
1. after i do a burn out,when the car creeping towards the staging lights i leave it in neutral and rapidly start pumping the clutch at least about 15-20 times, to try a disperse as much heat in the clutch fluid, to keep the fluid from boiling.
2. after the pass after i park the car i pop the hood and i pump the clutch about 30 times.
3. let the car cool for 30 min hop back in and pump the clutch pedal again another 30 times.
4. let the car cool for 30 min(1 hour total) then make another pass.
#105
The dirtiest my clutch fluid ever was I can equate to the color of honey.
Thanks 1paver.
Ron
#106
#107
Glad you brought that beautiful truck for some fall fun at MIR. It ran consistently well. Joley shot three videos of your passes. 11.15, 11.16, and 11.15. I'll do some editing, put them up on my server and send you a discrete link to download them.
Hope you can join us again next fall.
Ranger
#108
Pitt.
Ranger
Ranger
I will probably be in my Z on the next trip to see you guys ! I need to drop my 10.66 to a 10.4 or less.
Pitt
#109
#110
http://forums.corvetteforum.com/c6-z...ck-on-drs.html
#114
What happened to 1paver's posts? His posts have disappeared???
#115
Nice run, John and thank you for your website It has help me to learn how to drive these Z at the track and saved me from destroying parts in the process. Unfortunately are track has closed forever so I may have to come join you at MIR! Its very nice to see those fast E.t's gives something to brag about on the GTR forums. Thank you again for being a great guy and for great advice to help your fellow racers!
#116
Learning to drive fast cars without breakage is one of life's interesting challenges. It's always reassuring to learn the the technique cribs shared broadly on the www have helped another owner at the track.
Sad to read of another track closing. Many are struggling in the down economy. Fortunately, MIR, Cecil County, Capitol, Atco, Englishtown, Orlando Speedworld (OSW), and Palm Beach International Raceway (PBIR) have weathered it so far.
Ranger
#117
WOW, the C7 has some BIG shoes to fill. I wonder if the next gen vette will be capable of such feats?
Congrats on the fantastic driving, you are a real wheel man.
Tom
Tom
#118
Thanks for the very generous words, 427silverhotrod.
Sad to read of another track closing. Many are struggling in the down economy. Fortunately, MIR, Cecil County, Capitol, Atco, and Englishtown have weathered it so far.
Ranger
Ranger
#119
I have a lot of faith in the GM engineers and production team. Suspect they will impress us again with the C7 and new Z06 and ZR1.
My Z06 is a Feb 2006 car. 27K miles. Not missing a beat after 300+ passes. The drive train has been bullet-proof so far. No oil consumption. Still a well-maintained car that's not been a garage queen.
Ranger
#120
Not only is the driver mod the most cost effective by far (save maybe nitrous), it's a pretty fun to beat guys who have spent significantly more than you because you can outdrive them.
And I personally really enjoy working with people as they learn. Recently JustinJor went from 1.9's and mid 11's a couple of months ago to 1.5's and 10.8's last week - no mods, no significant weather changes, just studying the tips of the hot shoes here on the board, learning to read scans to find areas to focus on, and practice.
Both the teacher and the student enjoy this kind of progress and it's fun to pass it along.
