[Z06] Battery Tender HookUp
I bought a Battery Tender to maintain the battery in my Z06. This is the first car I've had where the battery is in the car. The Battery Tender comes with either alligator clips or ring terminals to attach to the battery. The ring terminal has a mechanical disconnect for when you are not charging to make it very easy to attach and disconnect the Battery Tender from the battery.
The first problem is as I was removing the nut holding the cars battery cables and dropped the darn thing; it is now under the battery. I can't get it with a magnetic pickup.
The second problem is now that I've removed the batter cables and hold-down strap, there isn't room for my hands (on either side of the battery) and to be able to lift the battery out of its compartment. Is there a strap or tool GM uses to attach to the battery and lift the battery out?
Also, there is a drain on the side of the battery with a rubber hose that I disconnected. If the battery is tilted to far, does battery acid leak out this port?
Last question, if I use a Battery Tender to maintain the battery in the car, do I need to keep windows open to ventilate the car?
Thanks in advance.
Thanks in advance.
I suggest doing a "Search" on Battery Replacement. There has been a ton of threads on it.(How to get it out and in) There are also posts about how to connect a Battery Tender at the battery location
The hose is a vent to get gasses out of the car interior. Otherwise an explosion might happen with you in it. I don't think it will hurt if you tilt the battery.
I connect alligator clips under the hood as I always open it anyway after a run.
Thanks in advance.
Thanks in advance.
http://www.autogeek.net/battery-tend...r-adapter.html
Let me help you out here and introduce you to the wonderful world of cigarette lights adapters for your tender.... You can thank me for it later...
Thanks in advance.
Thanks in advance.
The tips here will help you get the battery out. Get yourself some Gorilla Tape. The hose is a vent hose. It vents gasses outside the car. Do not disconnect it.
http://forums.corvetteforum.com/c6-z...with-pics.html
I have used both the clips, and the "permanent" hookup, described here.
http://forums.corvetteforum.com/c6-c...ry-tender.html
Though this is a base C6, the technique will work in a Z06 as well.
I crack the windows when I have the battery tender on, in case the hose alone is not enough to vent the gasses over a multiple mont period of the car sitting over fall and winter.
I've been using it for a year with no problems . I have it hooked up under the hood . The red clip goes to the red cable and black to a ground bolt .
There is a diagram in there showing you where the black negative bolt is .
I crack the windows when I have the battery tender on, in case the hose alone is not enough...
As far as the search function. It's a great tool; I use it often. In fact, I've got hours into pouring through old posts to determine the way I want to approach preventing rock chips on my quarter and rocker panels. The bottom line is there are times when I just don't have the patience to search and read and read and search; other times, I just don't feel like it. I'll even bet I'm not alone...
Thanks again for the help.
Frank, I am not sure what model you have but the cable on mine is so thin the door closes right over it. There is actually a tiny notch on the door sill as well which you might be able to use, but mine is so thin it isn't needed. (in case you don't feel like leaving the window cracked)
Hey Vito. I honestly don't know why anyone does it any differently. I see so many crazy methods and it makes my head spin. The only thing I can think of is if people have old school tenders so they choose to use them. my duracell cost me under 20 bucks
[/QUOTE] This was easy to hook up and you don't have to mess with the battery. Its easy to plug in and unplug. If you don't want the cable draped across the car it can easily be sent up from under neath the car.
I attached the leads to the jump station under the hood and ran the line to the front grill of the car. I secured the connector and weather cap to the upper left corner of the black grill with a zip tie. When I park the car in the garage I just connect the Battery Tender. It takes about 5 seconds to do. The battery is always on the tender and 100% anytime I use the car.
Is the neg. connection on the frame the way your picture shows it ,ok. On the picture on the fusebox cover, it looks like it connected to motor. Does it matter where neg. ground on charger is connected ?
You are talking about the cable from the Cig lighter correct? I'll have to check that out had not even thought of routing it through there. I'd rather leave the windows shut actually. Thanks for the tip. I'll check that out tomorrow. Will work nice too when I get the car cover on.
Yes Frank, actually you can open the door a crack and run the cord between the fender and door. There is a spot where it fits perfect and you wont have to open the window at all. By far the easiest way to use a battery tender. One of the benefits of having a hot lighter outlet when the car is not running.
