[Z06] C6 Z06 Rotor screw up
#81
also lets not forget that all 4 rotors have cooling ducts forcing air through the brakes.....higher flowing than previous models....the direction of the vanes in the case of the z06 probally makes little difference.....
my.02
my.02
#82
Originally Posted by jvp
Yes, there would be. When the vanes are facing the 'normal' way and the wheel is turning forwards, the air is moved from the center (hub) outwards towards the wheel. The vanes, combined with centrifugal forced caused by the spinning rotor, will shoot the air outwards and help cool the rotor.
If the vanes are facing the 'wrong' way, then the air doesn't move through the vanes correctly. If at all. The rotor essentially turns into a spinning air scoop. But the centrifugal force is still going to try to push the air outwards, away from the rotor's edge.
Bad juju.
jas
Bad juju.
jas
#83
Jim is right about the vanes not pulling air if they aren't drilled. How would they? There is no exit (or entrance - whatever). They are a dead-end. If they were "throwing" the air from the inside to the outside, they would create a low pressure situation in the rotor, and if they were "scooping" air from the outside to the inside they would create a high pressure situation in the center of the rotor. But there would be no airflow without holes in the rotors.
However, I suspect that we are delving into an area which very few people know as much about as they think...
Obviously the people who are supposed to know about it (GM's engineers), didn't think it mattered. And considering the fairly hardcore attitude they took on this car, if it did matter they probably would have addressed it.
On the other hand, holes in the rotors are silly, but they did that anyway...
#84
Go out and do some 70 to 10 mph braking several times rapid succession and then pull off and measure the rotor temperatures on both sides, front and rear and report the results. If the front rotors are about the same temperature and the rear rotors are the same temperature then vane direction doesn't matter!
#85
From the evidence of this thread, Vette owners are highly opinionated, rather intolerant, somewhat biased, and exceptionally prone to take offense.
Most of the folks asking questions, and many of those answering them, are just trying to be helpful in good faith. No need to flame someone unnecessarily.
Baer seems to have it right (centrifugal airflow inside to out with internal vanes sweeping the airflow inside to out). The externally seen slots and drillings are counter to the internal vanes and point in the opposite direction, lending confusion. Source: my 95 Vette w/ eradispeeds.
GM apparently has chosen the cheap way out yet again. Guess Baer will get an order from me on my forthcoming C6 Z06.
#86
the vanes are open to the inside of the rotor as well as the outside...they flow air regardless of the cross drilling....
#87
Received 3,835 Likes
"Ask Tadge" Producer
Originally Posted by jschindler
My contention is that if they are not drilled, there is no way for air to circulate THROUGH them. Does this make sense?
Cross-drilled (or cast-in) holes in the rotor surface are there primarily for pad out-gassing. The concern here is that pads form a pocket of hot gas and don't come into as close contact with the rotors as they should. The holes help the gas from the pads escape into the interior of the rotor.
Now, today's pads don't out-gas anywhere near as much as ones from the past. So cross-drilling (or cast) doesn't help as much as it used to. However, any time you increase surface area, like, say, drilling holes, you help in cooling.
jas
Edit: I see that jschindler is a bit confused as to what we're talking about. The vanes in question go from the hub all the way to the edge of the rotor. In other words, the area between the rotor surfaces is open, and air can move from the hub outwards. The cross-drilled holes have nothing to do with this.
#88
Originally Posted by TA
That being said I'll still say that I don't think its going to make any difference.
Been there, done that, got the skid marks.
jas
#89
I say, don’t sweat it.
Stock cross drilled 1-piece heavy POS will probably crack at the track pretty fast anyway and should be replaced with nice lighter 2-piece solid ones
#90
Originally Posted by tkrussell
From the evidence of this thread, Vette owners are highly opinionated, rather intolerant, somewhat biased, and exceptionally prone to take offense....
Huh? Us, opinionated, intolerant and somewaht biased...
Okay, I'm good with that!
By the way, since my last post, I see two people have agreed with me, and one has disagreed.
I'm very sincere when I say that I apologize if I was wrong. I still don't know for certain if vented rotors are open on both ends, but I sure didn't think so,
#91
As you can see, they are definitely vented all the way through, pulling air from the center and forcing it outward. I am assuming that a Z51/Z06 rotor would also be the same but I have nothing to confirm that.
To clarify too...I really dont have much of an opinion on whether it adversely affects performance enough to make a difference. JDogg said something above about there being something like a 7% difference in efficiency so I'll just go with that. My only contention was that I didnt care for the looks.
#92
Thanks for that picture, I can now see why Baer positions the rotors they way you see them. The vents scallop towards the back, like your hair in the wind, but the holes go foward. Most companies don't do that, they usually match the holes with the vents. I think that pic will also show jschindler how the vents work.
#93
#94
that is what a factory rotor looks like, just the hub is cast into the rotor. Have you ever even taken off of a rotor before?BTW no offense but we don't need the answer, I know what a rotor looks like, and "somewhat" how it works. Picture is for you.
#95
Now, the reason I actually came back to post is that I have searched for more pictures, and while I couldn't find one that showed both sides, I found some that indicate that I was, in fact, wrong. Therefore, you have my apology, and I stand corrected.
#96
The theory behind all this is, air has mass, mass has weight, the rotor is acting as a centrifugal air pump, moving air from the center of the hub, through the vanes, and exiting around the circumferance of the rotor. Cooling takes place as the air flows through the vanes.
This type rotor is normally referred to as a "vented rotor".
"Non-vented rotors" are solid cast rotors lacking internal vanes.
The cross drilling and slots provide no enhanced cooling characteristics for the rotor, they do provide an escape route for gassing that is produced under extreme braking conditions. They do not increase surface area as somebody eluded to, but exactly the opposite, they decrease the surface area by the total area removed from the rotor surface either by drilling, or the grooves made for the slots.
Cross drilling can promote hot areas around the holes during braking that are prone to producing cracking around the holes, chamfering the holes helps but probably cannot eliminate proness to cracking.
Now I know somebody will ask why Chevy put cross drilled rotors on the Z51 and the new Z06.... you should ask the design team. Maybe they want to increase parts sales, they want to sell rotors?
...and yes you do see cross drilled rotors on track cars, they do work under extreme braking to release the outgassing, but remember those track cars get new rotors almost every time out.
zo6vettepilot
#97
Originally Posted by ZO6vettepilot
Exactly. BTW, there are two types of "vented rotors", both provide increased cooling to the rotor. The first type has vanes that are cast radially from the center of the hub to the outer diameter. They provide good cooling characteristics, and X amount of surface area for the metal to air cooling. The second type of vane is cast radially, but is curved. When correctly installed, the curve is to the rear when the vehicle is driven forward. This type of vane is more efficient than the straight vane rotor because the curved vane can create higher velocities therefore they move more air for a given rotational speed. The curved vane also elongates the sectional of the vane, thereby increasing the internal surface area and creating a larger cooling surface for the air to act upon for cooling.
zo6vettepilot
zo6vettepilot
#99
#100
Lol
This post has been the most entertaining. Did I spell entertaining correctly? If the car has directional rotors then the car should have left and right rotors to be correct, period. Even if there is only a 1% difference in cooling.
The reality is that for most owners to drive hard enough to tell a difference in the rotors is only a wet dream. Many would run out of talent and stuff it into the wall first. The rest that track their cars will change to aftermarket brakes because that's how the universe works. You either prepare the car with the uprated parts first, or, you change what breaks with better aftermarket parts and come back next weekend.
