Corner exit snap oversteer, very annoying... how to fix?
2008 coupe, 23k miles, stock tires with 4/32" left, diff has been changed to the new fluid, endlinks have been replaced within last 5k miles, alignment *SHOULD* be spot on, tire wear is even. Car is stock besides an intake.
I'm noticing on almost every corner now corner entry and mid corner and fine and quick, but even at low speeds say 35 out of the corner on exit as soon as I let go of the throttle (while i'm in 4th @ 1500rpm mind you, not attacking the corner hard at all) the car immediately fishtails left/right and then my hands and active handling bring it back.
I checked my "new" endlinks and they move very easily left to right and have some binding and popping.
anyone have experience with this? I didn't want to go buy new endlinks again or tires quite yet...
Original 5-6 year old tires. That's my guess as the problem. Rubber may be old and harder, plus the GY's are just terrible.
Stock tires are so horrible it's actually impressive that Goodyear was able to sell them to GM.
I've never noticed a change like I did just from swapping tires.
I know everyone is going to say "stock tires suck", but any steps to confirm the behavior before I go buy new ones if they're indeed the problem?
The behavior of my horrible original tires are exactly how you described in my experience. I need to change mine, as they are older and harder now and are absolutely taking away from enjoying the car as it was meant too, and they are dangerously unpredictable in anything but hot dry weather.
Received 2,240 Likes
Could you explain what "but even at low speeds say 35 out of the corner on exit as soon as I let go of the throttle (while i'm in 4th @ 1500rpm mind you, not attacking the corner hard at all) the car immediately fishtails left/right" means.
If you are saying that midway through a corner you let off of the gas and the car fishtails then it has nothing to do with tires. Something in the suspension is broken.
This is the first car I've driven where I thought "holy ****, if I screw up, this will get really ugly really quick without any ability to save it." It reminded me of my first time on a sport bike- the inputs are very sensitive and the machine is finely tuned. It's going to do what you tell it to do, whether it's what you want it to do or not, so be very careful. It just feels like it can bite very quickly and very hard.
http://forums.corvetteforum.com/c6-c...post1584002916
FWIW, I'm probably a mid pack driver at a track day. I'll drive in the middle of the three groups (beginning, intermediate, advanced) and be mid pack, assuming all cars are equal. Maybe even better. In a bone stock Camaro SS, I was probably 5 seconds faster than every car out there in the beginner group.
Also, that's somewhat the nature of the car. It's a 50-50 weight distributed car, but it has weight at the extreme ends (engine front, trans rear) and the tires aren't all that grippy or large. It has stiff relatively suspension so it won't squat under load and put weight on the rear. The tires have stiff sidewall and won't load up. It's just going to "snap" more than mustang or Camaro.
I think it's a combination of the car's natural characteristics and the tires.
All I found was the endlink play, i'll jack it up and pull on the wheels see if the tie rods are messed up.
entry and mid corner are fine, but when i'm through the corner and straightened out, letting go of the gas sends the rear sideways as the weight transfers. I also feel like it isn't nearly as competent going into the corner as it once was though.
One other thought though -- others on CF have reported cracks in their springs -- might check them.
St. Jude Donor '06-13,'16-'17, '19
Tom
I've noticed my car doesn't like engine braking in turns, at all. What gear are you in? I went through a turn yesterday and didn't heel toe. When I let the clutch out on the exit, the back end snapped around very hard. Aside from the whole rear end pulling back, it pushes weight forward and make the *** want to go around. Never lift, bro :p
If you're straightened out completely and out of the turn, then the back end snaps around, something is broken.
I'm confused, you're on the throttle coming out from the mid turn. When do you let off the throttle? At the clip point when you're straightened out or between bid turn and clip point? after clip point?
