View Poll Results: Harmonic balancer failure poll
I have not experienced a problem
547
64.13%
I think I have a problem now
73
8.56%
I have replaced it once
138
16.18%
I have replaced it twice or more
24
2.81%
I have replaced it, but decided not to use a GM part and went for an aftermarket unit
71
8.32%
Voters: 853. You may not vote on this poll
#141
No. The wobble is from the balancer down low in front spinning the belt. If faulty it can be seen wobbling. At times it squeals a bit too. If its going out its actually self destructing and if not replaced in time, can cause severe damage to other parts. If your motor seems to rock back and forth more than it should when revving you may have a cracked motor mount.
#142
#144
There's another post that just came out, someone's HB actually separated and the pulley moved back into the engine, there's pictures posted so you can see what happens when it really goes bad.
The name of the post is "Crank Pulley Out of Alignment".........
#146
Tolero Apto Victum
http://store.katechengines.com/bille...sioner-p2.aspx
http://store.katechengines.com/ati-s...ts-v-p230.aspx
I have read a few threads about people who use a different pulley and have problems later on, but I never heard of anybody having a problem with the ATI balancer. 07 with 150,000 miles on it & no problems with my ATI!
#147
MT
#148
Just picked my car up yesterday, local well respected garage mechanic (Certified GM Corvette Mechanic) did my ATI replacement. Said the old one wasn't too bad but my thinking is better safe than sorry and it did have a pretty good wobble in it. He had the car a week, total price with labor, the ATI, ARP bolt and 2 new Gates belts was $832.
#149
Tolero Apto Victum
#153
06 with 64K with a lot of wobble. Ordered HB and bolt along with a pin kit(might as well pin it while in there). I have access to a lift. Anyone know about how long it should take to change it? I know what needs to be done, just want to know how long it took to change it out.
#157
I bought my car with 40,000 miles on it. Was slightly wobbling when I bought it. I used it to get the price down. I'm gathering my cam parts and will do the cam when I replace the balancer with an ATI unit.
I test drove 6 c6s before I bought this z51 manual. Every car had a wobbling pulley.
#158
Tolero Apto Victum
Very smart, save on labor charges.
