GS Wheels on a base coupe
here is what the front will look like with GS wheels on a base front end. Stuck out about a half inch, never had a problem with the car lowered.
The link in post 8 of this thread is a good example of how poorly the C6 GS wheels fit a C6.
Just wondering what problems could arise: debris thrown up from wheels, turning and clearance issues with front tires, etc.
Thank you for the link to the photos.
If you use your OEM size tires on the front (245), then you can get by with GS wheels (on the front) just fine.
The problem is with the back. The OEM GS wheels are 12" wide with a different offset so they will stick out past the fenders about 1/2". It looks bad and if you hit a pot hole or a big dip in the road, you are taking a chance that the tires will hit your fender lips and possibly do some damage.
In many states, having the tire sticking out past the fenders will not pass inspection. Some states require the fender cover the complete tire and some states require the fender to cover the tread of the tire. Also many states say that the tires can not touch the fenders.
Cruising
GS Wheels On base C6
I had some on my base C6 but was nervous about the potential for hitting the fender. However, if you need some GS wheels with runflats, mine are still for sale:
http://forums.corvetteforum.com/c6-p...es-w-tpms.html
