Battery tender
Battery tender
Hi folks. I just bought a battery tender for the winter. The instructions say to connect it to the battery but my Vette has a remote positive located near the fuse box. If I have to jump start that's where I would connect the positive. Should I also use the remote positive when I use the battery tender or should I connect to the battery?
Others can chime in but I'd say you can use either one; whatever is most convenient and offers a direct connection to the battery. I use a CTEK charger with the ciragrette lighter plug that I connect to the cigarette lighter socket in the center console.
Are you talking about a permanent connection or where to put the clips? Electrically, it won't make any difference. The remote connection is meant to minimize the danger of a spark when connecting jumper cables which could cause a battery explosion.
Thanks all. I kinda thought the remote positive is the way to go for the same reason as when you jump it, which is to avoid sparks. Just wanted to make sure the battery would still get "tended" that way.
Last edited by Vette_DD; 10-12-2012 at 01:24 PM. Reason: Non-supporting vendor links
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
I hooked up the one that has the magnetic hook up in the front bumper opening, I hooked it to the remote too as a permanent install. No issues and so easy, if I forget to unhook it, it just comes off as I back out, so simple.
It is an awesome piece and so easy to use.
Got mine here from forum vendor
http://forums.corvetteforum.com/c6-c...ry-tender.html
Please keep these forum guidelines in mind when posting about buying products from a non-supporting vendor that forum vendors sell.
Commercial posting
Supporting vendors pay for the considerable bandwidth charges on the Forum, making it free for the rest of us. In exchange, they get the privilege of using the Forum to market and promote their goods and services.
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (address, phone number, e-mail address, URL, price, part number, offer to send contact information via PMs, etc.) or so frequent that they become marketing and promotional references.
I have it too, it doesn't connect to the battery anyway, so you will be fine
Received 1,504 Likes
