(VIDEO) NEW Product The Most Revolutionary Method To Hook Up A Battery Tender
Old 03-29-2012, 07:50 PM
Top Flight Reproductions
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Default (VIDEO) NEW Product The Most Revolutionary Method To Hook Up A Battery Tender
Just get in and drive away (see the video), can be adapted to any car!!!!!
* Stop running wires into, on top of and over your car to charge it.
* Never forget to unplug your charger and cause damage to your car.
* Even charge your car if it’s 100% dead and you have no access to the battery.
* Set it and forget it, charge your car every day.
For all Z06, also works for the C6, GS, Zr1 and C6 (complete plug n play kit $74.99 ($5 off for the forum) Battery tender not included. I guarantee the best investment you will make in keeping your car charged.
I refused to have a battery tender prior to this because I would not run wires over my car or through the window. I wanted a simple attach and drive away method so I would not have to worry about disconnecting it. No you can charge the car and not worry about someone else having to disconnect it to use the car.
I hooked the battery tender cables (one with eyelets) to the + on the fuse box and the ground on the frame. There is already an opening in there by the horn to run the wire so no cutting or modifications.
The connectors are a proprietary system that use a magnetic system to couple and only engage power once coupled. It's amazing since you can't hook it up incorrectly and once disconnected no power at the car side so no chance for a short (plus the tender cable is fuse protected anyway). It's also 100% water (can take pressure washing), dust proof and hooks to the standard battery tender connectors.
For now I have a simple mount that just slips on over the grill and can be removed anytime (most likely the spring/summer season). I just get in the car and drive away (see video). Other big plus is that if the car was dead and you did not have the tender hooked up, you could just pop it on and charge the car without getting in.
ORDER LINK
Click for Video
Old 03-29-2012, 09:24 PM
drich2905
drich2905's Avatar
Old 04-02-2012, 06:41 AM
Old 04-02-2012, 06:46 AM
VET4LES
VET4LES's Avatar
Old 04-04-2012, 06:14 AM
Originally Posted by VET4LES
Old 04-04-2012, 02:41 PM
lsbrodsky
Support Corvetteforum!
lsbrodsky's Avatar
Great device! I love mine.
Larry
Old 04-04-2012, 04:46 PM
gpotski
gpotski's Avatar
Just ordered one online.
Thanks,
Gary
Old 04-04-2012, 06:12 PM
Swiftrider08
Swiftrider08's Avatar
Pretty much the best engineerined and best solution for hooking up a tender. Once all wired up, connection is a "snap" and takes only a second.
No opening the hood, opening the window, running the wires under the door, worrying about your car cover, nothing! And those few times when you forget all about it - no problem - it just disconnects itself when your backing up (if mounted in the front of course).
This is a device that even works well for the rear mounted battery guys with the Grand Sports, Z06's and ZR1's or any vehicle with an interior mounted battery. Could even be used on a motorcycle.
Heck, I even have one on my John Deere Tractor!
Old 04-04-2012, 08:41 PM
AeroJim
AeroJim's Avatar
St. Jude Donor '08-'09
Larry
Just ditched my cig lighter connection for this, Vast improvemnt, and well worth the money.
Old 04-05-2012, 07:20 AM
Larry
Thanks,
Gary
Old 04-05-2012, 09:43 AM
Ghost 23
Ghost 23's Avatar
Top Flight Reproductions: This is a very appealing connection. You show the charge port mounted in a vertical configuration. Because it hangs down from the bumper in that configuration, I think it detracts from the front-view appearance of the vehicle.
Can the charge port be mounted in a horizintal configuration? That is, flat against the upper portion of the bumper fascia? Or, would that cause shorting problems when the connector disengages from the charge port when backing up?
Old 04-05-2012, 07:36 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
Just ordered a CTek one
Old 04-07-2012, 06:21 AM
Yes you can mount it in the horizontal configuration
Old 04-07-2012, 09:39 AM
Ghost 23
Ghost 23's Avatar
Great. I just tried to order but could not figure out how to get the $5.00 Forum discount. Please advise.
Old 04-10-2012, 06:18 AM
The $5.00 discount is already deducted from the price.
Old 04-10-2012, 06:36 AM
turbod
turbod's Avatar
Ordered and payed for through Paypal on 4/4. I have seen no shipping details. Paypal transaction shows "unclaimed".
PM sent with details.
Also, I did not see the drop down box specifying CTEK which is what I have. Can you correct that before shipping?
Old 04-10-2012, 04:39 PM
If you placed an order for one of these prior to 04/11/12 please contact us at topflightrepro@yahoo.com to confirm that we received your order. We had some issues with paypal checkout (our fault) so please contact us to verify.
ORDER LINK
Click for Video
To (VIDEO) NEW Product The Most Revolutionary Method To Hook Up A Battery Tender
Old 04-10-2012, 04:51 PM
mcandrew67
mcandrew67's Avatar
sent PM and Email on my order from April 5th
thanks
Old 04-10-2012, 05:44 PM
mcandrew67
mcandrew67's Avatar
Cancelled and re ordered
thanks, let me know when it ships
David
Old 04-12-2012, 06:06 AM
David
Thank you David
Quick Reply: (VIDEO) NEW Product The Most Revolutionary Method To Hook Up A Battery Tender
