160 stats??
160 stats??
are 160 temp stats worth installing?? I have a ls2 (07) and was wondering if and how much the cooler temps would help. any info is helpful. just purchased a C6 vert.
Without a tune it will drop the temps while you are cruzing. Once you hit the red lights the temps will go back to what you are use to seeing. With a tune the fans will be set to come on at an earlier temp, and the temp will remain constant, probably about 180 to 190.
I mentioned a tune.....I assume you can set your fans to come on sooner without actually doing the tune.
Bet it gets at least 3 more by 2014....any takers?
put one in
modify your tune
call it a day
or sit and wait for another one of these long legthy debates/pissing matches/what eva ya wanna call it
will it help??? all depends, there are just to many variables/what if's/etc
to me... it certainly helps get rid of some heat, and can even help with interior temps
at least we noticed a difference in my wifes 05
i also never had problems with 160 stats in frigid cold temps either
modify your tune
call it a day
St. Jude Donor '13
My C5Z ran great with one, but it was tuned also. Very cool (no pun) to see the thermostat nice and low on the dash. I have no experience with one in an LS3 however.
Exactly
I have a friend who works at a southern cal dealership and he says they are designed to run like that-- what most of us would consider Hot
There's one reason right there. Reason number two is that these cars are designed to run hot. Have you ever tracked your Z with coolant temps down in the 150-160* range with that 160* thermostat? The car will run like a dog.
Do a search for posts by forum member Evil-Twin.
He provides very useful information pertaining to 160 stats. He is a retired GM engineer who worked on the C5.
The sweet spot for LS engines, according to E-T, is 190/200 coolant and 200/210 oil.
Was he the one who designed the engine around running the factory stat? If he I take back my first parts of this messages.
Here we go with being an engineer.....I know a few people who were for GM. One of them designed part of the dash in the 3rd gen F-body and the other designed carbs in the 60s/70s. They dont know everything about every single part.
