Roof creaking
Condition the rubber seals. I use Di-electric grease (silicon grease). You can buy the big tube at any of the auto parts stores. A little messy the first few washes, but your seals won't dry out.
It's really a silicon grease - not silicon spray lubricant. Typically used for lubing spark plug boots when performing a spark plug change. This is what GM recommends as well. You'll find it in the gasket sealer section of your auto parts store. Either Tune-up grease or Dielectric grease - same thing.
Richard, can you please provide info on the type of shrink tubing you used, i.e. diameter, thickness, etc.? Also, after sliding the tubing onto the pins did you heat it to make it "form fit" the pins? Thx.
GUARANTEED TO WORK.
Go to Home Depot/Lowes and get some 3/16" or 5/16" e-clips. Put them on the little roller shafts that rotate. 1 per roller. NO MORE NOISE!
Navigator
i cant wait to try this! that creaking is terrible in my 05, i was just going to try and buy a new one but now theres hope! mine even does it in cold weather... terribly annoying.. thanks for the info
Received 2,054 Likes
St. Jude Donor '13
GM has a long bulletin about how to fix the creaking roof, use the Search feature to find and print it out.
Go through it, step by step. Hopefully, most of them will not apply to you and you can skip them after checking. Then if you have the old style front latches, you can do the E-clip fix by mrtoner and save a bunch of money.
Otherwise, don't waste your time on scattershot fixes.
Get the bulletin, do the bulletin.
Our car had six problems that all had to be fixed, now the roof is quiet. The dealer worked through it and finally found/fixed them all.
Thanks,
Laura
GM Customer Service
