Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette General Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Old 03-02-2008, 08:20 PM   #1
mrtoner
CF Senior Member
Support Corvetteforum!
mrtoner's Avatar
Send a message via AIM to mrtoner
Default UPDATE - New Approach to Fixing Top Popping Noise
NEW UPDATE - JUNE 6
Few weeks ago I switched tops - put the e-clips in the latches, and no popping sound - at first.
On some roads, I got a VERY faint pop - only noticed because the radio was off [plus I think I am tuned in to that sound].
Checked the e-clip, still in place and roller immobilized - But I also realized I had not lubed the roller shaft.
Just to make sure, I looked at some of the other posts, and saw the one to put shrink tube on the front pins.
Went to Fry's electronics and got clear 1/2" shrink tube; shrank a piece onto each pin, and it has been totally noise free for 5-weeks now, and the outside temp is getting up there.
So it might be that the best TOTAL solution is lube the roller pin, then install 2 e-clips; for extra assurance, 2 lengths of shrink tube.....
UPDATE - ADDED VIEW TO HELP WITH INSTALLATION....
3/4 update - 75 miles and not a sound....
3/8 update - 200miles and still good
3/14 update - 350 miles and still good
3/18 update [last one] - over 2 weeks and not a sound
Glad this has helped out!
My '05 didn't have the popping of the roof panel until I drove over some rough construction areas.
I read all the threads, and it seems the culprit is [mostly] the roller in the latch.
One recommendation is to jam in a small nail or staple to prevent the roller from moving. I did that and it seems to work, but I frankly could not see why preventing the roller from rolling would eliminate the noise.
I experimented, driving the car with the latch totally disengaged, and also engaged with the latch stopped on the tightest point, just before the final latching. In both cases, there was ZERO noise.
I believe that maybe it is the axial movement of the roller as the body flexes that creates the noise - either the roller moving on the pin, or actually bottoming out on the latch cradle.
[thanks to Y2KC5NBM for the original picture]
I looked at eliminating the fair amount of end play on the roller. I bought a pack of 5/32" E-Clips from Lowes. The clip snaps securely on the pin, and is just the right thickness:
I installed one as shown:
The thickness takes out virtually all the end play, but the roller still rotates as it should.
So far, no noise after two days - easy install, don't really have to remove the latch, but that makes it easier......
mrtoner is offline   Reply With Quote
Old 03-02-2008, 08:28 PM   #2
Batmbl
CF Senior Member
2005 Chevrolet Corvette
Batmbl's Avatar
Thanks for the great post with pics to boot. Keeps us informed as to how it works. I'll try it on my '05. Dealer has tried twice to fix it with no success. GM doesn't seem to have the answer; I hope you've found it!
__________________
'99 3xblk vert w/Twin tube intake, hood seal, Lloyds, window valet, clb, ZO6 Ti's, Magnaflow X-pipe, SS inserts, Optima Red Top, Falkens, Sequential Tails
'05 DSOM, bone stock(except for the Lloyds and the Window Valet and the ceramic brake pads)
Batmbl is offline   Reply With Quote
Old 03-02-2008, 08:31 PM   #3
ohmy
CF Senior Member
ohmy's Avatar
nice post, let us know how it is after driving for awhile, hope u found the cure...
ohmy is offline   Reply With Quote
Old 03-02-2008, 09:50 PM   #4
Snagle
CF Senior Member
Snagle's Avatar
Wow, interesting idea. It is certainly easy/cheap enough.
Snagle is offline   Reply With Quote
Old 03-02-2008, 10:02 PM   #5
NHNASCAR24
CF Senior Member
NHNASCAR24's Avatar
Great Tip. Mine does it but I was going to wait for the new GM fix. Yours looks a LOT better and easier.
Thanks!
NHNASCAR24 is offline   Reply With Quote
Old 03-02-2008, 10:12 PM   #6
VET4LES
CF Senior Member
VET4LES's Avatar
Thanks for the information.
VET4LES is offline   Reply With Quote
Old 03-03-2008, 12:38 AM   #7
chet b
CF Senior Member
chet b's Avatar
Thanks and let us know how it works out after you put some miles on your car.
chet b is offline   Reply With Quote
Old 03-03-2008, 12:44 AM   #8
Crystal Vette
CF Senior Member
Crystal Vette's Avatar
Location: Western Kentucky previously: Grand Island, Nebraska
interesting. Keep us posted and thanks for the pics.
Crystal Vette is offline   Reply With Quote
Old 03-03-2008, 09:52 AM   #9
dave pawlowski
CF Senior Member
dave pawlowski's Avatar
I eliminated the noise be putting some teflon tape between the roller and it's contact area in the windshield frame. When I examined the roller closely, it appeared to have a flat spot on it. I think the problem is the rollers are deforming and not rolling at all- they do slide a little bit during normal body flexing, thus making the noise. Seems different from this fix but whatever works! The problem area seems to be the roller.
dave pawlowski is offline   Reply With Quote
Old 03-03-2008, 10:18 AM   #10
ctgene
CF Senior Member
ctgene's Avatar
I get the noise very infrequently, but it is annoying...yours is an easy fix, so keep us posted...
ctgene is offline   Reply With Quote
Old 03-03-2008, 11:03 AM   #11
ClovisFox
CF Senior Member
ClovisFox's Avatar
Send a message via AIM to ClovisFox
GM has determined that it is in fact the movement of the rollers, even so slight, which is making the poping and creaking noise for the C6 clear tops. A proper and effective temporary fix is to immobilize the roller, either by slipping a thin spade into the roller and jamming it, or with some epoxy to prevent movement. GM has redesigned the latches and eliminated the rollers, replacing them with some kind of sliders which are afixed to the latches and do not move when the latches are closed. The last time I talked to them (late January) the new latches are scheduled for release in April.
Gene...
ClovisFox is offline   Reply With Quote
Old 03-03-2008, 11:11 AM   #12
sabooher
CF Senior Member
sabooher's Avatar
I guess I'll take mine in and get the new latches when they're released; that's if it annoys me enough.
So far I've been living with the occasional creak (cold weather) and pop (hot weather). Doesn't make a peep at normal (room) temps.
sabooher is offline   Reply With Quote
Old 03-03-2008, 12:34 PM   #13
thatdood
CF Senior Member
thatdood's Avatar
thatdood is offline   Reply With Quote
Old 03-03-2008, 01:03 PM   #14
Walt White Coupe
CF Senior Member
Walt White Coupe's Avatar
Mr Toner, you're a genius. Couldn't find the 5/32" e-clip at Home Depot so used a 3/16" e-clip. Fit just fine. Was on a 200 mile trip yesterday and the top "ticking" drove me crazy. Just went for a 10 mile trial after installation and not a peep from the top. Best $0.38 I ever spent. Thanks again!
Walt White Coupe is online now   Reply With Quote
Old 03-03-2008, 02:51 PM   #15
ohmy
CF Senior Member
ohmy's Avatar
the roller pop and snap doesnt bother me, bc mine goes away very soon after the drive starts... what doesnt go away is the weatherstripping to glass contact squeeks, and that drives me nuts!
Old 03-03-2008, 03:24 PM   #16
mrtoner
CF Senior Member
mrtoner's Avatar
To all:
To see if the noise you have is caused by the latch/roller assembly:
UNLATCH THE NOISY SIDE AND TAKE A DRIVE.
IF THE NOISE IS GONE, THEN FOCUS ON THE LATCH/ROLLER.
IF YOU STILL HAVE NOISE, THEN LOOK ELSEWHERE.
I emphasize the above because some of the threads on top noise are not consistent with what I call the 'popping' noise.
Old 03-04-2008, 12:57 PM   #17
mrtoner
CF Senior Member
mrtoner's Avatar
Bump
Old 03-04-2008, 07:48 PM   #18
DrivnXcitment
CF Senior Member
DrivnXcitment's Avatar
Brilliant!!!! Nice job finding a fix for this. I am going to go out tomorrow and get clips for mine too. That top is driving me crazy!
DrivnXcitment is offline   Reply With Quote
Old 03-04-2008, 10:28 PM   #19
Batmbl
CF Senior Member
Batmbl's Avatar
Default clips
Quote:
Is it necessary to remove the latches to install the clips? Is your top still quiet?
__________________
Old 03-04-2008, 10:51 PM   #20
Batmbl
CF Senior Member
Batmbl's Avatar
Got the e-clips installed. Will test drive tomorrow and let you know how well it works for me. While at it I also wrapped the pointed attaching pegs with teflon tape. My fingers are crossed.
__________________
Reload this Page New Approach to Fixing Top Popping Noise
Tags
08, approach, c6, clips, corvette, eclips, fixing, makes, new, noise, pin, popping, problems, roller, sound, top, update
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
