FOB - how to open
FOB - how to open
I would like t know how to open the FOB for my 2008 coupe so that I can change the battery?
When I look, I don't see any apparent slots etc anywhere around the edge of the seam in the plastic case.
2008 owner's manual, page 2-9:
1. Insert a flat object with a thin edge into the slot on
the side or back of the transmitter and separate the
bottom half from the top half.
The Dealer attempted to open mine for some reason and handed it to me in pieces with a "promise" that they would get me a new fob and program it for me. 2 phone calls and no response so I gave up on the Dealer and put it back together myself, I'll live with the gouges and marks the Dealer made on the fob before I'll let them touch my car again.
I'm sorry, maybe I'm just crabby today, but why do we need to have senseless questions being asked on this forum, when all most people need to do is read their manual and use common sense. Sorry, just having a bad day. Needed to vent a little.
1 Post
My solution turned out to be to use an eyeglass screwdriver. It helps to have something small to work your way around the case as they crack easily.
Oh, by the way, I hope you have a better day tomorrow.
Funny thing is that I tried to open as per the manual, cracked the case and my dealer replaced it for free under warranty. So some dealers aren't bad but I am still weary on letting them do some things.
But sometimes there's more info that is helpful.
For instance, the manual doesn't say anything about lubing the fob o-ring with a little silicone grease. This makes the fob easier to open next time.
And some folks have reported problems with the gridded surface of a Rayovac batteries.
More tips & discussion:
http://forums.corvetteforum.com/c6-c...y-warning.html
The manual is a good place to start. And I agree that it's annoying when someone is too lazy to take that first step.
I'll agree with the above - I followed the manual instructions and broke mine from my 2008. After seeing how it is built I have no idea how you would actually take it apart without either gouging the sides or breaking it. "Maybe" a putty knife on the non-key end. Don't admonish the OP for asking as it sure isn't obvious when you read the owner's manual and then inspect the fob. It's not like earlier fobs with a nice slot for your dime or quarter to pop it open.
The side with the logo is only a "shell" on the outside of the fob, and if you insert something inside the fob to try and pop it open you will break it. Yes, I speak from experience.
Either there is a trick to opening the 08 and later fobs that is not mentioned on this board (I've searched), or there is a GM tool to do it, or GM just wants to sell lots of $100 fobs. I look forward to learning the trick so that when my #2 fob battery dies I don't break that one too.
Patrick
Patrick
The silicone also makes it much easier to snap the halves back together. Always snap the fob open and closed when it is warm...if the fob is cold, like in winter, it will be much easier to crack it. Warmer the better...leave it in the sun for a few minutes before messing with it.
Received 3,129 Likes
Finalist 2020 C7 of the Year -- Unmodified
To the original poster GOOD question was looking at my 08 fob and was wondering how I was going to open it to replace the battery when it is dead and I did read the manual and it did not help with a solution. Thanks to the forum members that give great info PROBLEM SOLVED!
I found it really really hard to open the case and had to use so much force that I was actually scared of breaking it. Seems excessive, but that's how it's made.
Im currently having the time of my life trying to put both the little bastards back together. I found this thread and didn't think of silicone. Now to get some...I'm afraid to use any more force to snap them together.
The problem is getting them apart without breakage.
how to open Corvette C6 2010 key fob
Hi, make sure the fob is warm, about body temperature. Remove the key and face the buttons up, If you have strong thumb finger nails gently place your finger nail in the seam at the corner by the lock icon button. Rock your finger nail in gently or place both in the seam, nail side top of right to nail side top left to act as a prying tool, and it will separate with ease. Once it starts to open, slide your finger nail down to the long side to where the key was. It should easily open like a clam shell. Do this on a soft covered table top to catch all the parts. Replace the battery and snap back in the reverse of above. If you have to force it, try again on the other edge. If you do not have strong finger nails, you can use the edge of an old credit card, If you have trouble catching he edge, you can sharpen the card a bit but don't make it sharp enough to cut yourself.
I would not use a metal knife as it will damage the fob plastic and you can cut yourself if you slip.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
