TMPS (failed sensor) & new tires - question
I'm about to install new tires on my 2007 Z51 coupe. (Decided to go with the Michelin PS2 ZP's - to be installed at Discount Tire).
The DIC had "xx" displayed for several months for the driver side rear tire. The Discount Tire guy checked with the tool and said the sensor is not sending out a signal. He wasn't sure if it's damaged or a bad battery.
Based on several posts in the Forum, I decided not to replace all the sensors to have fresh batteries - due to the age of the car and relatively low mileage (under 10k). For those who may ask - I've been out autocrossing and burned through the Goodyear F1 Supercars... In the future, I'll post my thoughts on how good/bad F1 Supercar vs. PS2's in another thread.
My questions.
- Is it possible that the sensor can be reset? Anyone else have a problem like this on a relatively newer car?
- Since I have a couple of days while the new tires are in transit, should I buy a replacement OEM sensor from the dealer/Gene Culley or should I go with the aftermarket one that Discount Tire sells? Discount Tire's price is a few dollars cheaper ($43 vs $58+) and it's easier, but I'm concerned about accuracy and mixing OEM and aftermarket sensors.
Thanks!
My questions.
Thanks!
If the sensor won't respond to diagnostic checks by the tool then, like the tire tech said, it's either damaged or has a dead battery. In either case, it can't be repaired and you'll need a new one.
I'm not familiar with the aftermarket sensors Discount Tire sells. Can you describe it? Who makes it? If it's orange and made by Schrader (Schrader part# 20076) then it's not aftermarket at all - it's the exact same sensor put in at the factory.
There are a couple aftermarket sensors out there that are compatible with the C6, so I'm inclined to say just go with the cheaper one from Discount.
Good luck!!
Bob
Good luck!!
Bob
Bob,
The Discount Tire guy showed me an example of sensor they use. He has to order the exact part for the Vette, but the one he showed me was white and made in France. I can't recall the name of the manufacturer, but it was short (3-4 letters). He also said they use "Berut", but that wasn't the one he showed me.
Sounds like you aren't aware of any accuracy differences or compatibility issues with mixing manufactures - correct?
Thanks for the info...
John
John
There is a guy in the C6 parts section selling sensors for I think $45 a piece. I have had a lot of issue with my TPMS senors also.
I went to a Chevy dealer and told them I needed one sensor reset due to it reading XX. They hooked up a tech 2 to my car. I asked why in the hell would they due that when i can put the car in learn mode and use the hand held to reset the sensor. He told me that wouldnt work. I wasnt happy with him, nor did I believe him. So, I went to another dealer and told them all I wanted was to use the hand held while the car was in learn mode. I put the car in learn mode. (accessory on, car not running, hold the lock and unlock button on the fob until the horn beeps once) He used the hand held and all the sensors reset and worked. Havent had an issue since.
I found out that those discount tire places dont seem to have the correct hand hel frequency for these sensors. Maybe try a dealer. Its a free thing for them to do and takes 2 mins.
Good luck....
Good luck....
I've never worked with true "aftermarket" tire pressure sensors, however, take a look at this thread:
http://forums.corvetteforum.com/c6-c...l-sensors.html
The OP in that thread reports that the Oro-Tek sensors work just like OE Schrader sensors.
Forum vendor Bob's House Of Wheels sells OE Schrader sensors for around $45 each.
What ever you get, you need GM Part# 25758220 or an aftermarket one that is compatible with that GM part#.
Bob
Bob
CF Senior Member
Good luck....
Good luck....
Whatever works for you but that's not my experience. The Discount Tire stores I deal with are well equipped to reset TPS's on virtually all vehicles (my own TPMS tool works on a wide variety of different make cars). Maybe some dealerships don't but many dealerships do, in fact, charge a nominal fee to reset tire sensors. If you're going to a full service tire store that can't reset a tire pressure sensor on a General Motors vehicle you definitely need a different tire store.
I would be better off just buying my own TPMS tool like you.
Received 8,953 Likes
Bob,
John
John
Bill
Here's the cheapest one I know of:
http://www.toolsurge.com/prodview.asp?sku=OTC-TIPS003A
Also, Tire Rack has the ATEQ VT10 for $105 + shipping.
Bob
Bob
