Oro-tek wheel sensors
Old 11-05-2009, 12:34 PM
Res1cue
Res1cue's Avatar
Default Oro-tek wheel sensors
Just received new aftermarket wheels sensors. They are manufactured by Oro-Tek. Very nice build quality and the stem can be seperated from the sensor. They are adjustable to conform to numerous different wheel profiles. The stems are actually nicer than OEM.
Old 11-05-2009, 02:53 PM
george vee
Support Corvetteforum!
george vee's Avatar
Received 1,073 Likes on 532 Posts
2015 C7 of the Year Finalist
What were the cost for these
Old 11-05-2009, 03:59 PM
Darrelk
Darrelk's Avatar
Ditto, cost and vendor source or were they direct from Oro-Tek???
Old 11-05-2009, 04:37 PM
Swiftrider08
Swiftrider08's Avatar
And why these and not the std GM ones? You have checked that they will work ok with the GM onboard system?
Old 11-06-2009, 12:20 AM
Res1cue
Res1cue's Avatar
My cost was 38.00 each which was the factor to go this route instead of oem. I have been assured that they are 100% compatible with the gm system or money back. Very well made unit just as oem. The company has been making tpms systems since 2006. The vendor is not a sponsor so just do a search for oro-tek in google and you will find them.
Old 11-06-2009, 01:57 PM
george vee
george vee's Avatar
Thanks, let us know how they work on the car. looks like you saved $100. ( corvette tax)
Old 11-27-2009, 10:27 PM
Res1cue
Res1cue's Avatar
New wheels installed today with the Oro-Tek sensors. They setup just like the factory units and preform identically, no issues.
Old 11-27-2009, 11:25 PM
cclive
cclive's Avatar
Nice info...thanks!
Old 11-28-2009, 07:43 AM
Res1cue
Res1cue's Avatar
Found another company that makes aftermarket sensors as well. Orange electronics. Google if you would like to find a vendor.
Old 11-28-2009, 08:26 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
just a thought: it works better in search engine if you type in "TPMS" after the company name.
Old 11-28-2009, 08:30 AM
GSRANDY
GSRANDY's Avatar
Programming?
Regards,
GSRANDY
Old 11-28-2009, 01:43 PM
Res1cue
Res1cue's Avatar
Originally Posted by GSRANDY
Programming?
Regards,
GSRANDY
Are you asking about programming the sensors? They setup using the same tool as the factory sensors and the exact same procedure.
Old 11-28-2009, 02:06 PM
MARSC6
MARSC6's Avatar
Is this where it came from? If so which model?
http://tpmsoutlet.com/tpmssensor-3.aspx?page=2
Old 11-28-2009, 09:24 PM
Res1cue
Res1cue's Avatar
Originally Posted by marsc6
is this where it came from? If so which model?
pm..
Old 11-28-2009, 10:11 PM
MARSC6
MARSC6's Avatar
pm..
Thank you
Oro-Tek Sensor Fits OE Application GM 25758220
To Oro-tek wheel sensors
Quick Reply: Oro-tek wheel sensors
