how to change the D1S low beam HID bulb in a C6 corvette, please help!
I'm trying to find someone who knows how to change out the low beam hid lamp on a 2009 C6, I know how to get to the bulb itself but it seams to have 2 fasteners which hold a retainer. if someone could even tell me what kind of fasteners they are or what kind of tool it takes to remove them, it would be a great help since I have these nice 8000k hid's to replace them and don't want to pay the dealer $110.00 to do it for me
I'll bump this thread for you by telling you that there doesn't seem to be anything in the C6 FAQ about it.
Also, here's what's in the 2009 owner's manual on page 5-56.
But I suspect that someone here has probably done it themselves. Maybe they'll respond.
The low beam high intensity discharge lighting
system operates at a very high voltage. If you try to
service any of the system components, you could
be seriously injured. Have your dealer/retailer or a
qualified technician service them.
I don't know if this will help. Take a look at it and I'll keep looking:
http://forums.corvetteforum.com/c6-c...placement.html
Edit: Here's another one, posts 7-11:
http://forums.corvetteforum.com/c6-c...beam-bulb.html
thanks buddy, it helps alot, I'll be going to sears tomorrow to get a magnetized 15 torx tip to take out the bulbs, i'm sure it will be less than 110.00 lol, thanks alot
I did my 05. It is easier to remove the front tires. Pull the heads out on the plastic fasteners and then pull out the fastener. This will remove the inner panel cover to access the bulbs. Release the plug from the rear of the bulb (squeeze Tab). Remove the torx screws (2) holding the bulb fixture. Pull back on the bulb and you will release it from the fixture. You will need to remove the sheet metal bracket from the old bulb and install it onto the new bulb. This slides off and is a friction fit. Slide the bracket onto the new bulb. Do not touch the glass filament with your fingers, hold by the metal base of the bulb. Repeat for the other side. Install is the reverse. Not really to complicated. I also replaced the High Beam bulbs with the HID kit.
just an upgrade, found the bulbs on ebay for 100.00 for the pair in the temp I wanted. I found the HID foglight kit for 45.00 so I'll be doing both of them at the same time, picked up all the tools I need to make this install pretty easy
Joe
Changing headlight from stock to 6000k does not make it brighter. If anything slightly dimmer. The higher the Kalvin the lower the lumens. The fog conversion makes night and day difference over stock. It actually completes the lighting experience. The HID fog are low and very wide. I have 6000k fogs over 2 years and love them. I had 6000k headlamp but have since replaced leaky assemblies which came with stock 4300 D1S. I'm just gonna leave it for now. It's not a perfect match but it's fine.
Joe
Joe
Where did you get these lights and did it require wiring or electric modifications or are they just plug ins?
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
For those factory fogs anything is an improvement especially HID fogs. Why didn't they install HID fogs from the factory to make it compatible with low beams which are HID and then why the standard high beams? I would think the whole system, all the lights would be HID to begin with?
I was going to put HID high beams in and then reconsidered for the same instant-on requirement reason. I just replaced the stock bulbs with PIAA bulbs, which are much closer in color and brightness to the stock HID low beams.
But fog lights don't necessarily have to flash on. You'll find that if you add the HID fogs you almost don't need your high beams. Almost.
Couple of tips if you do the HID fog light mod:
Don't put the ballast on top of the fog light housing. The extra weight will make the lights jiggle. Attach them to the frame.
While you have the fender liner out, find the fog light adjustment hole in the underside of the front bumper and follow it up to the fog light. You can raise them a little but don't over do it or else everyone will flash you.
Get some dielectric grease and put it in all the connectors, as long as you're in there already. This isn't mandatory but it will eliminate corrosion and extend the lifespan of your connections.
If you use 4300K bulbs they will match your low beams. 6000K+ bulbs look cool and are bluer, but are not quite as bright.
Adding HID fog lights is one of the best mods I've done to my C6.
YMMV.
Sorry if I hijacked the thread.
I agree that HID's are not normally used for the high beams because they take time to light up and you lose the flash-to-pass capability.
YMMV.
YMMV.
In another car I was running H-1 100 watt bulbs in the fogs which are now yellow that burn bright and real hot that could burn your hands but that headlight system was re-wired along with a 130 amp to handle the extra power of all the lights.
I've read reports about some bulb sockets melting from the extra heat generated form hotter bulbs. Some didnt know it until they went to change bulbs again, then noticed the melted sockets.......
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I thought that in real fog situations the bulbs would almost have to be a bit yellow to contrast the fog for better vision.
Anyone that has changed the fog lights to HIDs ever been in a real fog and used them?
I would like an input on that; It seems to me the HIDs would be almost blinding to use in a fog.
