Replacing Low Beam Bulb
Old 11-04-2007, 12:14 PM
tjl5709
tjl5709's Avatar
Default Replacing Low Beam Bulb
HID Low beam bulb, does it twist out?
Doing my HID fog light conversion and I going with 6000K low beams.
Old 11-04-2007, 08:03 PM
c6 rocket
c6 rocket's Avatar
Old 11-04-2007, 10:10 PM
jrpedraza
jrpedraza's Avatar
I have not changed mine yet, but I do want to 'convert' the factory low beams to 6000K along with the fog lights. Where are you buying you conversion kit?
JR
Old 11-05-2007, 06:06 AM
BlackZ51Vett
BlackZ51Vett's Avatar
To remove the low beams, I have heard the front bumper cover has to be removed.............
Old 11-05-2007, 06:43 AM
gota07
Support Corvetteforum!
gota07's Avatar
Cruise-In VIII Veteran
The service manual shows the headlight assembly has to be pulled to change the HID headlamp bulb. Not only does the bumper fascia have to off, the wheelhouse liner does also. The 6 upper front fender bolts have to be taken out to lift the fender for clearance.
I think I would still have to try to get to it through the access panel in the wheelhouse liner before I resorted to that procedure.
Old 11-05-2007, 07:40 AM
NEV3R L8
NEV3R L8's Avatar
Are you replacing just the D1S low beam bulb or the whole low beam system? Keep us up to date on how this goes.
Goodluck,
David
Old 11-05-2007, 11:29 AM
Joezone914
Joezone914's Avatar
If you are replacing the D1S bulb you do NOT have to remove the Bumper. Either turn wheel or remove wheel and there is a small access panel to get to the bulb. Since I had it done and watched I do not remember if the bulb just twists off or if there is a torx screw first.
For the fog light conversion it is easier to just remove the wheel and the whole plastic wheel well and you can access fog lamps and find a good place to tie up the ballasts. Hope this helps.
Joe
Old 11-05-2007, 03:27 PM
C62ENVY
C62ENVY's Avatar
I just converted mine this weekend and they are D1S and you'll need a torx-15 to remove the two nuts on each bulb... Be real careful not to drop the nut. I dropped one and had to retreive it with a magnet extractor.
I converted them to 6000K and did the Fog conversion HID 6000K too.
I also purchased a Craftsman torx wrench with tips magnetized.
Old 11-05-2007, 05:19 PM
tjl5709
tjl5709's Avatar
Yep, replaced the LB's with the 6000K D1S bulbs.
For the fogs, you need to take out the wheel well liner. Not hard at all.
The headlights have a rubber panel in the wheel well that you pull. Found the 2 torx 15 screws. Yep, and dropped one to.
Having 6000K fog and low beam HID's is bright. Didn't know how yellow every other headlight is until now.
I hope my new blue 100watt high beams look better than the stock ones. I wont know until I build my new wiring harness, but man, are they yellow compared to the HID's.
Old 11-05-2007, 08:33 PM
Joezone914
Joezone914's Avatar
You guys that just changed your low beams did you find D1S or was it D1C which is supposed to be universal but I am thinking not. I ordered D1S but received D1C and was told it's ok so I installed D1C 6 months ago but there is a focal point rather than a flat beam.
Also since i had it installed & though I watched I missed the torx scre part. Can someone explain or show a pic of where it was. Also did you reuse the torx screw or is the bulb a twist on.
Joe
Old 11-05-2007, 09:05 PM
tjl5709
tjl5709's Avatar
Got the Fog conversion and LB bulbs off EBAY.
Bulb is D1S, and it projects a wide flat beam like the stock bulb. I think the D1C bulb gives a pin point. It's not designed for a projector lens like on our C6's.
The access panel is inside the wheel well on the top/front. It is a rubber panel held inplace by pins that you pull. Once inside, the low beam bulb is in the middle behind another rubber grommet. Pull grommet, and you will see the bulb/ignitor assembly. The 2 torx screws are on the sides. The bulb does not twist out. Pull screws, and the hole assembly comes out. You need to remove the metal holder from the bulb, and mount it on the new bulb. Reuse screws to mount.
Old 11-07-2007, 03:32 PM
C62ENVY
C62ENVY's Avatar
(Note) Use a magnetized torx-15 wrench or be extremely careful when removing and replacing screw's.
Old 11-07-2007, 04:45 PM
NEV3R L8
NEV3R L8's Avatar
You don't happen to remember the eBay seller's name do you? Did you buy the LB bulbs and the fog kit from him together? Sounds like a good weekend project for me.
-David
Old 11-16-2007, 02:35 PM
tjl5709
tjl5709's Avatar
Ebay seller:nissangtrpower
They have both LB's and fog's
They send you everything you need. Simple to install.
Old 11-16-2007, 08:14 PM
axg2001
axg2001's Avatar
cant unplug the factory low beam conector....does it have a screw too, like the bulb..?
Old 11-21-2007, 02:31 PM
C62ENVY
C62ENVY's Avatar
No, I think it's connected like the rest. unscrew the two torx that hold the bulb in the housing and the black wire connections should be able to remove..
Old 11-21-2007, 04:59 PM
NEV3R L8
NEV3R L8's Avatar
Post pics and maybe some directions of what you had to do if you get a chance. I'm getting ready to do this as well.
-David
To Replacing Low Beam Bulb
Quick Reply: Replacing Low Beam Bulb
