Old 03-05-2015, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Targa top noise
Old 12-02-2009, 09:09 AM
minor5523
minor5523's Avatar
Default Targa top noise
Have anyone had targa top noise,poping.squeating, and rattling noise while driving if so what can be done about it to correct the problem.C-6 "05"coupe.
Old 12-02-2009, 09:11 AM
mrtoner
Support Corvetteforum!
mrtoner's Avatar
Yes - check out Talon90's sticky: "C6 roof panel noise primer"
Old 12-02-2009, 09:16 AM
not08crmanymore
not08crmanymore's Avatar
Immediately,you can put some lube/grease in the holes up front where the latches go.Right down in there where the shiny part is up front. Then,look in to new latches from the dealer that gm issued a while back.
Old 12-02-2009, 09:21 AM
RadarP3C
RadarP3C's Avatar
Had the new latches installed yesterday.
One day of quiet (no roof popping) so far....
Old 12-03-2009, 08:35 PM
minor5523
minor5523's Avatar
Thanks to all who replied to my thread I think the info will be very helpful.
Old 12-03-2009, 09:44 PM
ohmy
ohmy's Avatar
there is no permanent fix, the popping and squeeking will come back, there is no fix, just a temporary band-aid - grease, reposition, e-clips, felt, take your pick, all temporary...
Old 12-03-2009, 09:46 PM
nmerhaut
nmerhaut's Avatar
Did the e clips over a year ago and no more snap, crackle or pop. Good luck.
Old 12-03-2009, 09:51 PM
bob guzzy
bob guzzy's Avatar
Mine started making noise out of a clear blue, I just took the top off and put it back and it was gone and still is.
Old 02-08-2010, 12:25 PM
aloandnina
aloandnina's Avatar
Did you have to pay for the latches or was it more like a factory recall? If you had to pay, how much was it?
Old 02-08-2010, 01:06 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
If your car is under warranty they will replace the handles with the new design for free under warranty. If not, it will be out of pocket. The new design handles list for $160.00 each. Your cost will depend on where you buy them and if the dealer is willing to discount.
Part Number
Description
19206591
Handle, Roof Lift Off Panel - Left
19206592
Handle, Roof Lift Off Panel - Right
12371287 (US)
10953437 (Canada)
GM Vehicle Care Super Lube® with PTFE
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
Old 02-08-2010, 01:37 PM
Mike's LS3
Mike's LS3's Avatar
I must be lucky, two years and no more popping. I did the following:
1. Make sure the pins on the targa top are tight.
2. Make sure the roller retainers (the metal retainer the roller sits in when secured) do not have play in them. Bend the metal tabs to remove any play. One of my retainers were lose and made noise.
2. Install the e-clips on the rollers.
3. Lube the rollers, retainers and pins with Dielectric grease.
4. Apply silicone spray on the top weatherstripping.
Every six months I will lube all the above areas and (knock on wood) no more popping or clicking.
OR GET THE NEW HANDLES, BUT SOME HAVE REPORTED THE NOISE RETURNED!
Old 02-08-2010, 06:16 PM
LS WON
LS WON's Avatar
or buy a hardtop = Z-06
Old 02-08-2010, 06:33 PM
aloandnina
aloandnina's Avatar
Can you show me a pic of the e clips?
Old 02-08-2010, 07:55 PM
PARANORMAL
SUPPORT AUTISM
PARANORMAL's Avatar
St. Jude Donor '10, '14
You may want to check out this other thread, I had the same problem and I went to Sears and bought the clips and a little grease and its all gone. It's amazing, if your out of warranty is $160.00, go to Sears and spend $1.00 and you get the same result.
http://forums.corvetteforum.com/c6-c...ing-noise.html
Old 02-08-2010, 07:58 PM
beaversstonehaven
beaversstonehaven's Avatar
Same here. Thanks Mrtoner! I never thought that fix would work but in my case it did the trick.
Old 02-08-2010, 08:11 PM
Dif
Dif's Avatar
I usually treated the weather stripping on my 09 about once a month since new.
It took about 7 months before I started getting the popping sound.
Treated the weather stripping and put a little white grease on the pins and rollers.
Stopped the noise right away
Old 02-09-2010, 01:17 AM
Mike's LS3
Mike's LS3's Avatar
Do a search: "5/32 e-clip top repair" Go to post #23 for a picture of the e-clip and where to install it.
Old 07-19-2011, 12:37 PM
robforster
robforster's Avatar
My GS coupe without rollers in the handles pops like popcorn with any tweak of the body or pothole (California). Lubed many times. Dealer lost. There used to be a link for those without rollers and the fix including gromets on the posts, gluing the plastic to the windshield, etc. Anyone have it? About 20 pages long
2010 GS Coupe
To Targa top noise
Quick Reply: Targa top noise
