is it possible to change the shift knob on an 05 auto
Yes. You can get Leather from Gerardo at www.dsvettes.com and laminated from Jersey at www.apsisusa.com (need to call to order). Both are fantastic products, quality, and customer service. The trick to removing it is finding the small slot in the back to remove the C-ring that holds it on. Once you find the little slot use a very small (eye glass ones work) flat-blade screwdriver to pull it out.
maybe a better question is can I replace the **** with a different style/design? I know I can get it recovered, just wondering if an alternate style is out there.
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Actually, the '05s (A4) use the same shift **** as all the C-5s. Several aftermarket ***** available.
