[Z06] MAF retaining clip part number?
Anyone know of a part number for the gray plastic retaining clip for the MAF sensor. I had one of those "OH S!*T" moments when mine went flying down into the engine bay. Searched for about an hour. I'm guessing its a goner. See Maxx Schlick's post for a picture. It appears to be a C6 where as mine is a C5, but you get the point:
http://forums.corvetteforum.com/c6-z...-maf-plug.html
TIA!
TIA!
FYI
I could not find just the grey (gray) retaining clip, but I was able to find the entire plug.
Here is google search criteria:
Acdelco Pt1274 Sensor Mass Airflow Connector
2003 Chevrolet Corvette Z06 5.7l
mass air flow connector standard motor products s-1262
http://www.amazon.com/ACDelco-PT1274...ype=automotive
Delphi (GM) part number 15317832
It's called: "LOCK, CPA AXIAL, GY LT" which, translated means: Connector Position Assurance, Axial, Gray Light (light gray), Lock.
It fits a connector (body) part number 15305555 which is what your 5-pin MAF uses:
Mouser carries this lock and currently only has 35,800 on hand @ 17¢ ea. so get one before they're gone.
http://www.mouser.com/Search/Refine....d=829-15317832
You're in luck however, as Mouser has no order minimum for anything they have in stock, so order (their) part number 829-15317832.
www.mouser.com
Btw, if the two "legs" seem a bit too long, you can carefully shorten them with a razor blade (or X-acto knife) just enough, so it slips in and locks correctly. Shorten only a little at a time. I had to do this on another one in the past.
HTH
www.mouser.com
HTH
FYI
www.mouser.com
HTH
www.mouser.com
HTH
www.mouser.com
HTH
www.mouser.com
HTH
or search for part number: 15317832
