[Z06] Easy removal of MAF plug
I have seen posts of some guys having a hard time getting the MAF plug off.
The MAF (mass air flow) plug that is on the driver side of the air filter box can be dificult to remove unless you find out just where to squeeze the release clip.
1.) First pull back the little gray retainer locking clip with a small screw driver.
Be carefull not to pull it all the way off , it should stay clipped to the plug.
2.) this shows where you have to put your finger tip underneath the plug.
3.) then squeeze the release clip as you pull the plug off, it should slide right off with no resistance once the release clip is squeezed.
4.)this shows the plug removed and upside down so you can see where your finger tip has to push on the release clip.
When you get the plug off turn it upside down and take a close look at the release clip and you can see how it holds the plug in place and how you have to depress the clip so it comes off.
5.To replace just push it back on till it snaps on then push back in the little gray locking clip.
6.) When you have the air filter box off it is a good idea to take the rubber pads out of the air intake box. Otherwise they can come loose and get sucked down the intake.
bjmsam (06-17-2018)
Thanks for the pics for sure!
Two questions though:
If you take the hydrocarbon pads off as you suggest, whats to absorb the oil that has deteriorated the adhesive. Granted, it seems like a poor design, but I'm reluctant to remove them unless i can replace with something else that serves the intended purpose....other thoughts/comments?
Any pictures of the adjustment to the rubber PCV line to make it fit correctly.
"Cut 1 3/8" out of the PCV line. Plug each end into a 2 ¾" piece of 3/8" i.d. rubber hose until the two cut ends meet. Put the line back in."
I don't have the KB yet, but I don't fully understand the instructions...the 2 3/4 piece your adding back in....what do you use to splice it in? Is there yet another revision that makes yet a better fix? I didn't see anything on Jim's web site....did I miss it? Doesn't appear the install video was updated?
Your thoughts/comment would be appreciated.
Your thoughts/comment would be appreciated."Cut 1 3/8" out of the PCV line. Plug each end into a 2 ¾" piece of 3/8" i.d. rubber hose until the two cut ends meet. Put the line back in."
The PCV system routing, as with most EPA required applications, has considerable problems, topic addressed in other threads.
It appears the PCV hose is just repositioning for appearance, not function.
St. Jude Donor '08-'09
Great write-up, just what I was looking for to take the grey retainer off.
Thanks,
augydog
I know I'm digging this one up from the dead, but I just found the thread after searching through Google looking for a walkthrough just like this and it was really helpful. I just cleaned out the MAF sensor on my '07 Z06 with electronics cleaner spray while cleaning out my throttle body.
Law Dawg Moderator
