DTC B0363 Left Actuator Feedback Open
*sigh* vette troubles. I cleared out most of the codes now.. so I think I'm near home stretch finally.
One last code that I clear but keeps coming back:
Can anyone give me extended info on this particular trouble code?
Is this related to the Throttle Actuator Module needing replacement?
B is BCM codes.
Its probably a mixer actuator on your automatic climate control system. Does your car have dual zone?
With an open code, I'd check for connections, both on the BCM and on the widgets mounted on the AC box under the dash.
The exact error is 99 HVAC - B0363 H.
You think this is related to my other thread?:
Thread regarding HVAC
Originally Posted by 2ndVette
"One thing that will make you scream "Doh" is if you failed to connect a very tiny swizzle stick looking vacuum line to the rear of your intake manifold. If it is not connected your AC will work improperly..."
