New AC compressor - need a new bolt?
In researching compressor replacement, I came across some notes pertaining to 2000 and older Vettes.
The note said to replace one of the compressor mounting bolts with bolt #11518775.
I assume a small change was made in the compressor in the '01 timeframe, and a shorter or longer bolt is now required in one of the 4 mounting holes?
Is this true, anybody know about this?
Tks,
DG
Tks,
DG
I would also like to know!
Tks,
DG
Tks,
DG
WHEN ORDERING 1137031 FOR VEHICLE 2001 & PRIOR, WILL NEED TO ORDER BOLT 11518775.
Thanks,
Steve
i put a new delphi compressor on my 98 and i reused all the bolts and stud worked fine.the compressor write up on here doesn't call for replacing any bolts either his is a 2000
http://forums.corvetteforum.com/c5-t...-write-up.html
I want to bring this to the top to see if anyone knows the answer. I need a new A/C compressor for my '99, and I ran across the same info, it said:
It must be a longer bolt than the stock '97 - '01 A/C compressor bolts. And I assume this means just one bolt, but is it one or two or all four??
Thanks,
Steve
Thanks,
Steve
