Air/Fuel Gauges - Whos uses them?
I was thinking about fitting a pair of wideband AFR Gauges to my 03 Z in order to help with accurate tuning , Most gauges on the net are JUST gauges, im looking for a complete fitting kit, sensor and guage etc setup.. obviously ill either need two, or some kind of system which can read both headers collectors... so im wondering what everyone on here uses? brands/models/prices etc...
Thanks,
Terry.
N.Ireland
Thanks,
Terry.
N.Ireland
Thanks,
Terry.
N.Ireland
Thanks,
Terry.
N.Ireland
http://forums.corvetteforum.com/c5-t...install-3.html
im no expert on this, but surely on high RPM's, you normally have a AFR in the tailpipe when tuning on a dyno? as far as i know, this isnt ever hooked up to your tuning software etc... but is used to be sure the motor isnt running rich/lean. if it runs either of these, then you adapt the tune to match?
And having an AFR closer to the Block than the tailpipe makes for more accurate reading.
I run a PLX setup on my MN6. I use EFI Live for logging/tuning.
http://redshift.homestead.com/WBO2.html
On the wife's, I had a bung welded in at the driver's side X but have not installed a WB setup on that one yet.
Former Vendor
If you want the most accurate longest lasting wideband on the market, I would recommend the NGK AFX Wideband Kit.
http://forums.corvetteforum.com/c5-f...onal-cost.html
NGK Powerdex AFX Wideband Kit $259.99
Seth
Seth
Hinson Supercars has the NGK AFX with the most accurate NTK sensor on sale!
www.hinsonsupercars.com
Thanks,Matt
Thanks,Matt
Seth
Seth
im actually being told to do a bung near the tail pipe after my turbos (remember im rear mount) cuz that air will be the most accurate?? and cuz of the rear mount the pressure pre turbo would show richer than it really is. whatcha think?? and to go with the AEM uego.
