DIY install instructions for a FAST 90/90
You can grind down the heads of the valley bolts or purchase new ones from SEARS that have a much shorter head.
As for the MAP sensor:
http://forums.corvetteforum.com/show....php?t=1727067
yes, I had one then sold it for a cheaper fix. It has you block off the rear, extend the wiring harness, then drill a new hole in the top of the FAST and it holds the map in with the metal bracket and bolt. The kit I bought looked really nice (anodized red), but I deemed it an uneccessary $80.
