Fix for F.A.S.T. MAP Sensor Location
Old 06-09-2007, 01:47 PM
Face
Face's Avatar
Default Fix for F.A.S.T. MAP Sensor Location
Ever since I installed my Fast 90/90, my idle hasn't been the greatest. Even after a tune, it would sometimes surge, etc.. And at the track, I noticed my 60's weren't as great even though I saw a nice torque increase(20lbs/ft).
I installed some new Comp Cams gaskets and the Lingenfelter MAP relocation for the LS2 this morning. The MAP relocation moves the MAP from the back of the manifold to the EGR provision near the front of the manifold. Just drill a small hole in the EGR provision, place the MAP and base in place, and secure it with the hold down. Then you have to bore out the old MAP hole for the plug included in the kit. The kit also comes with a plug and play extension harness for the MAP.
After letting the car idle a while and taking a ride around town, it appears my idle surge is gone. It idles as smooth as it did with the LS6 intake.
Since my MAP sensor is now clear of the firewall, hopefully my 60's will improve again. I couldn't be happier.
The kit is a little pricey for the pieces you get, but for the difference it made on my car, it's more than worth it.
Here's a pic from their website.
http://www.lingenfelter.com/store/ln-bk28kit.html
Old 06-09-2007, 02:37 PM
vettenuts
vettenuts's Avatar
Any photo's of it installed? I did something different, but am always open to ideas.
Old 06-09-2007, 02:59 PM
Face
Face's Avatar
This isn't from my car, my digital camera recently broke.
Old 06-09-2007, 03:02 PM
vettenuts
vettenuts's Avatar
So the MAP goes in the small hole and the aluminum clip keeps it in place?
Old 06-09-2007, 04:24 PM
Face
Face's Avatar
Yep. I can take a picture with my phone tonight or tomorrow.
Old 06-09-2007, 04:53 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
That looks like a nice kit. That kit should come with the FAST manifold when you purchase it.
Old 06-10-2007, 09:48 AM
RWE 427
RWE 427's Avatar
Old 06-10-2007, 12:02 PM
ArKay99
ArKay99's Avatar
Mike, good find and a big for posting it. I've been considering looking at relocating my MAP and this looks like the best way to go.
Thanks.
Old 06-10-2007, 12:47 PM
zeevette
zeevette's Avatar
Is the LS2 MAP sensor the same as the LS6? In other words, will this work on all FAST 90 installs?
Old 06-10-2007, 05:42 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Old 06-10-2007, 06:46 PM
c5mtl
c5mtl's Avatar
i just bought my fast ...i cant beleive i have to spend more ....
Old 06-10-2007, 06:52 PM
Face
Face's Avatar
No idea, but it worked fine on my LS1 MAP.
Forgot to take pictures. I'll do my best to get a couple tomorrow.
Old 06-10-2007, 10:33 PM
thetorch
thetorch's Avatar
The MAP sensor seal is the same for both LS1 and LS2 so this will work for LS1 and LS6. You will need to extend the MAP sensor harness to reach the front of the manifold.
Old 06-10-2007, 10:34 PM
Face
Face's Avatar
Luckily the extension was included in the kit.
Old 06-10-2007, 10:44 PM
thetorch
thetorch's Avatar
I'm with you on that. I'm really unimpressed with the overall quality of the FAST intake compared to the cost. I just purchased a FAST 90 and it needed attention right out of the box. Here is what was wrong with mine:
1. All of the injector holes in the lower manifold had to be punched out and sanded. What's with the quality control?
2. The o-ring seal between the middle and top was squeezed out in 3 places and hanging into the ports. The top and middle were not sealed correctly.
3. Unacceptable amount of casting flash on the lower intake with many, many sharp ridges. Reminded me of a cheap snap together model with all the tabs hanging off of it.
4. 2 of the 6 nuts that hold the upper and lower together were twisted and almost stripped when tightened from the factory.
IMHO, the FAST is a sub $400 intake when looking at the quality. It could at least come with stainless hardware instead of off-shore half rusted black oxide.
Not impressed with FAST, but it's the only game in town. What a shame.....
Old 06-10-2007, 10:48 PM
thetorch
thetorch's Avatar
So the wiring harness extension came with the kit? Great to know, Lingenfelter doesn't state this in the website.
Old 06-10-2007, 10:51 PM
c5mtl
c5mtl's Avatar
mine is being ported by vengeance so i hope all the f up's you are talking about are not there.....do all the fast need map reloction???how do i tell if i do?
To Fix for F.A.S.T. MAP Sensor Location
Old 06-10-2007, 11:03 PM
thetorch
thetorch's Avatar
I'm sending mine to Tony Mamo for porting, but I'm still unimpressed.
You don't have to relocate the MAP sensor on a C5, it will work in the location specified by FAST. However, it is much easier and your guaranteed that it will seal correctly if you relocate it.
Bottom line, it's your choice if you want to relocate it. It is highly recommended that you do. You can also leave it at the back and run a vacuum line to it 'tee-d' off of the 1/4" vacuum port on the drivers right rear of the intake where the A/C connector goes. Just make sure you plug the hole in the top if you relocate it.
Old 06-10-2007, 11:40 PM
NeverT00Fast
NeverT00Fast's Avatar
Old 06-10-2007, 11:45 PM
Face
Face's Avatar
If the car was left idling in P for a few minutes it would surge. Above idle I didn't have any problems.
Quick Reply: Fix for F.A.S.T. MAP Sensor Location
