Air duct options for CAI
Hey CF,
Looking for options to open the duct where the fog lamps are to allow more air flow to my Blackwing.
I don't think I want the wire mesh inserts. Can I modify the current plastic block out? Why is it blocked anyway? I would think it should have been designed to duct air to the intake.
Thx
Thx
Do this instead. It is called the "zip tie" or "flip tie" mod. You will have a lot less dirt and sand all over the engine compartment and I mean a lot. I know what it is like in Arizona and your engine will have pounds of dirt under the hood if you drill those holes. The zip or flip tie mod will give you the coolest air you can get into the intake.
http://forums.corvetteforum.com/c5-t...m-diy-yes.html
Received 19,451 Likes
'20-'21-'22-'23-'24
For the OP - you can either buy new fog light surrounds that have holes already cut in them (can get them from most major vendors - Mid-America, Ecklers, etc.), or you can simply drill a series of holes in the stock plastic surrounds.
If I read his post right, he already has a Blackwing on the car so no way he can do a zip tie mod unless he puts the stock air intake back on the car.
I could be mistaken but don't they make a cover for the Blackwing that gets air from in front of the radiator? The filter is going to get very dirty either way.
You can always do the front license plate cover screen mod. Just keep scrolling through this DIY thread.
http://forums.corvetteforum.com/c5-g...cover-mod.html
