C5 Problems/Reliability
Old 08-24-2010, 03:22 PM
9986mkoh
9986mkoh's Avatar
Default C5 Problems/Reliability
Are there any common Problems with C5 Corvettes, or even specific years of them? I've been looking at some and most seem to be in good shape, but I was wondering if there was anything special to really look out for with them. Or if anything in particular generally goes out once they're above 100k, or if it's just hit and miss... Thanks for any input on the subject.
Old 08-24-2010, 03:25 PM
ieatyllwcryns
ieatyllwcryns's Avatar
black 2000 coupe here w 85,000mi on it and ZERO real issues so far w it.. knock on wood..
Old 08-24-2010, 03:45 PM
jornahow
jornahow's Avatar
2002 coupe - 72,000 miles just ABS ($150 absfixer) dim/dark HVAC display and Techron for my gas gauge; other than that just regular maintenance (Money spent on mods doesn't count. ) Oh I forgot, I think the original owner had the leaky diff seal fixed under warranty.
Old 08-24-2010, 03:59 PM
Great White North
Great White North's Avatar
My rear tires wear too fast !!
Old 08-24-2010, 04:03 PM
Kale
Kale's Avatar
My 04 had its water pump replaced before I bought it at 28k.
Recently it had lifter problems and they were fixed. I'm at nearly 60k now.
aside from that... tie rod end... headlight gear. eh.
Old 08-24-2010, 04:05 PM
c5BlackBeauty
Corvette C5 Enthusiast
Support Corvetteforum!
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
Sticky, Sticky, Sticky........top of the page (weights, measurements, etc.) Take a look.
Old 08-24-2010, 04:18 PM
03WhiteConv
03WhiteConv's Avatar
As a Corvette breed the C5 is much improved over the previous generations. However, they are still (as a breed) riddled with problems. Don't get me wrong, it is completely worth it to drive these cars everyday. Here are some things you may eventually "learn" about the C5:
1. Electrical grounding issues wreak havoc with ...fill in the blank.
2. Sensors/modules that go bad; Steering wheel position sensor, Oil pressure switch, hazzard light switch, turn signal stalk, ignition switch, ABS/AH/TC module to name a few
3. Mechanical failures include headlight gears, valve springs, leaky butt, rocking seats
4. Driving carefully to be sure not to scrape the nose or rockers on speedbumps or driveways etc
These are all common but may not happen to every car. The good news is that there are already inexpensive fixes for most things like this that you can do yourself if you are comfortable around tools and cars.
I wouldn't let any of this stuff deter you from a purchase unless you can't do any work yourself. In that case you'll need some deep pockets every now and then to keep her on the road.
Old 08-24-2010, 04:19 PM
Tech
Tech's Avatar
There are lots of things that could go wrong.
Old 08-24-2010, 04:25 PM
Bills03Coupe
Bills03Coupe's Avatar
That's a "Right Foot" control problem, very common on C5's.
Old 08-24-2010, 05:39 PM
jol
jol's Avatar
Owning a C5 is fantastic. I"ve had 8 Vettes before this and this is really the best (2004 Vert.)
The major prolem which occurs everyday during the Spring and summer to every Vette owner, is the addiction to buying mods!!!
Take care of it...it will take care of you!
Jeff
Old 08-24-2010, 05:43 PM
Cryptos
Cryptos's Avatar
2002 EB Coupe, purchased at 11k miles now at 16k.
Passenger headlight gear
Headlight switch wouldn't enable running/gauge lights
Bad ignition coil cylinder 7
Low oil level sensor
Ripped driver side door actuator will lock but not unlock vehicle
RDCM flakey, doesn't always do what I tell it to do
EBCM fixed at ABSfixers (usual symptoms, no tcs/abs/ah)
Yup, that's about it for now.
Old 08-24-2010, 06:01 PM
Bluefire
Bluefire's Avatar
...and don't forget that annoying grin that will give you face cramps.
Old 08-24-2010, 06:06 PM
12png
12png's Avatar
I have a 97 w/192,000 miles. I replaced the transmission at 90,000 (auto). The oil sensor 2 times. The ground is a problem if you are not aware of it. Simple fix.
Old 03-31-2012, 07:53 AM
actionexpres
3rd Gear
actionexpres's Avatar
I just bought a 98 Vette with 100,000. One of the things that bothers me is that I can't check the trans fluid. I don't know whether I should change it, or leave it. I've heard if the fluid has been changed on a regular basis, that it is good to keep changing it. However, if it hasn't been changed, and then you do change it, the new fluid can "clean" the trans and create problems. Thoughts?
Old 03-31-2012, 07:59 AM
baxsom
baxsom's Avatar
common problems discussed often here
leaky butt-differential seals going and leaking fluid
headlight motors
Column lock
EBCM
bushing in seats going out causing the seat to rock
window seals
synchros bending
oem batteries dripping acid onto the wiring underneath
window controls stop working
complete PITA clutch install.
BevChem (07-10-2020)
Old 03-31-2012, 11:45 AM
ALLEGRO
ALLEGRO's Avatar
The C5 was designed to go 300,000. Your mileage may vary
Old 03-31-2012, 11:49 AM
rebelheart
rebelheart's Avatar
None of the above mentioned problems are not what we see every day of the week across five car lines.Nothing unusual here at all.
To C5 Problems/Reliability
Old 03-31-2012, 12:36 PM
Z06ster
Z06ster's Avatar
Many comments above summarize the common issues well. Here is my list
(My car is a 2002 with 60K on the clock)
1) Fuel sending unit assemblies going out resulting in busted gas gauge
2) Leaky butt - and 4 years after fix, problem has resurfaced
3) Headlight gear gone out
4) Door control module problem resulting in inability to lock door
5) HVAC actuator going out resulting in blasting heat on driver side and ice cold blowing on passenger side
6) Bent Synchros -- this one is the worst because I am not looking getting a rebuilt transmission
7) But of course, we must not forget the dreaded column lock!
Comments:
1) Many will tell you on the forum that Seafoam or Techron concentrate resolves the gas gauge problem. Not true in my case, I had dealer replace my fuel sending units and gas gauges work great now (and ONLY Chevron gas put in the tank ever since).
2) Most items above were small and thanks to this AWESOME forum, I fixed the issues myself
3) The synchro problem does suck... I am looking to have my tranny rebuilt. I do have a FI car so that probably accelerated the loss of life
4) I found out from the Forum, that C6 shaft seals are better than C5 shaft seals. I will try them on the next go around for the leaky butt problem.
Despite all these issues, do I still love my C5Z? Absolutely
Old 03-31-2012, 12:39 PM
JACKAL0PE
Lepus-temperamentalus
JACKAL0PE's Avatar
Indeed
http://forums.corvetteforum.com/c5-g...ngths-etc.html
When in doubt, read the directions.
Old 03-31-2012, 10:11 PM
QCVette
QCVette's Avatar
The link Jackalope provided is a good one.
I also think the harmonic balancer should be mentioned. It frequently wobbles and/or separates.
I didn't see it mentioned in this thread or the one Jackalope provided the link to (although I only looked at the first 6 pages).
Quick Reply: C5 Problems/Reliability
