Change your own shocks!
Last week I posted asking for tips on how to do it. You can follow all of the suggestions at:
http://forums.corvetteforum.com/show....php?t=1948904
The "CLIFF NOTES" version:
This site is easy to follow: http://fuzzydiceracing.com/test.htm
Extra advice came from Chip (Willfulone) reminding to compress the shocks, both coming off and going on.
Oh, and he also recommended an American Microbrew (did that - Victory HopDevil! )
Thanks again for the input - it went very easy except for having to use a hex wrench to tighten the front shocks on top - had to remove the tanks to get to the shaft.
No big deal - take your time - you'll be spending quality time with your car!
I used those same instructions.. With the corner jacked up the top of the shock tower was exposed through th ewheel well and I could get the open ended wrenc h on it without having to remove the overflow tanks....
Unlike the stock shocks, the Bilsteins have a hex fitting that you must approach from the top. There wasn't enough room under the fender to get to the top of the shock. I was able to get the open-ended wrench on the nut, but I needed to keep the shaft from turning. Wasn't really a major problem though.
Hi There,
You bet aircraft safety wire (.032") is about50 times stronger than electrical tie-offs, which should be used on wire bundles.
Glad that it worked for you.
robsc501
robsc501
I used the same directions a couple of months ago when I changed mine. They were definately a big help to me. I must confess though, the one tool that I used was a couple of Coors Lite :o
Received 19,305 Likes
'20-'21-'22-'23-'24
Good tutorial - thanks for the link.
