Changing shocks - any secrets / tips?
Check out the link. I followed this when I changed mine. Went fairly smooth.
http://fuzzydiceracing.com/test.htm
Serious question, though - do I need to use Corona or can I use a micro-brew?
changing shocks- any secrets/tips
HI There,
You bet aircraft safety wire .032" is what I would have used.
50 times stronger than electrical tie-offs,which should be used to secure wire bundles.
Glad it worked for you.
robsc501
robsc501
Received 19,439 Likes
'20-'21-'22-'23-'24
That link looks pretty good - will be saving it for future use.
