Painting cam covers
Painting cam covers
Has anyone tried painting the cam covers while still being installed on the engine? I am concerned about removing all the bolts and having problems later on due to not applying new sealant to the heads.
Can the master cylinder be unbolted and moved out of the way without disconnecting the brake lines? My 91 has two braided brake lines coming from it instead of rigid lines.
Thanks.
Thanks.
Thanks.
Thanks.
http://jerrysgaskets.com/store2/root...roducts_id=565
http://www.dragtimes.com/parts/CORVE...528616871.html
Thanks.
Thanks.
Post 68 - Eliminating TB Coolant and Air Induction, Added Oil Catch Can and Painting
awesome job. I'd like to do this too. it's a hassle pulling the cam covers off, but there is obviously alot of prep work getting a high quality refinish
I'm amazed at how nice your car looks doing it "in the car"
what did you deinstall (brake booster is really tough)
thanks!
thanks!
There is a company that makes caliper paint; "G2" its good to 900 degrees and is self leveling(brush on). The calipers I have seen look great and they also make engine paint and have the ability to make custom colors.
http://www.g2usa.com/product/G45.html
Removing and Painting Cam Covers
thanks!
thanks!
1. Cam Covers were removed by first removing Bolts from C-Frame, Loosening Engine Mount Bolts and then dropping Transmission a bit so cam covers could clear Brake Booster (two Torx-40 bolts near brake booster were removed with cam cover). On the Passenger side the Temperature sensor for Evaporator was removed easily and set aside (plenty room to then remove cam cover bolts and then cam cover on passenger side). The Transmission was lowered to remove the Cam Coover Torx-40s on passenger side and then raised to remove Cam Cover on Passenger side so Cam Cover could clear Fire Wall bolts.
2. Now the Hard Part......as can be seen five Torx-40 Cam Cover Bolts failed in the Torx receiver on the bolt head even though considerable downward pressure was applied to the Torx-40 socket/wrench. Several types of Torx 40s wrenches had to be used because of the clearance. Considerably more torque than the 19 ft-lbs for Torx-40 Cam Cover bolt installation was applied trying to remove them (a cheater on a 1/2 inch socket wrench)
3. Now the Easy Part........What to do.....Drill, Heat....Torch...
a. I tried drilling and ruined three drill bits.
b. I did not want to try heat (A little heat works great on Injector Housing for removal of Coolant Manifold Bolts) as there is no way to get heat where it is needed.
c. Chisel...........well wouldn't you know it.....Using a chisel to first notch one side of the Torx-40 bolt to gain a purch and then pounding that side counter clockwise with the chisels about 10 times without touching the Aluminum Cam Cover surface popped the bolt loose (all five). I would never have guessed it but ran out of options.
Cam Covers Removed Engine In Car...............................Note the chisel marks on the Torx-40 bolt heads
Cam Covers back on (The easy way with SS Allen Head Bolts) and Belt tensioner installed with belt
and New Belt Tensioner Pulley
4. Painting Cam Covers ........................................ .............and Plenum.
thanks!
thanks!
It really was not that bad to do.
