New Exhaust 94 C4
New Exhaust 94 C4
I thought I would just make a new thread and ask my questions. I just bought a 94 C4 Convertible with 32k on the clock. Really nice car but it sounds way too mellow to me. I just got a rid of a 85 and it had way more aggressive sound, but it didn't drone. I don't want one that is going to drive me nuts just driving down the road either. I just want it to sound like the sports car it is.
So I'm looking for exhaust advice. I don't want it super loud but I would like it to be a lot more aggressive than it is now. I found a couple systems I like the looks of on Amazon I'll post the links below. I really like the looks of the Borla and the square tips. If anyone has any experience with any of these I'd like to hear about it good or bad. Also this is just what I found briefly searching I'm not in any way locked into these. I'm open to just about any suggestions. I listed them in my preferred order. Though I don't know that I need to do the entire exhaust system to do what I want? I was really thinking all I need is the axle back? The muffler on the drivers side has started leaking, I had a little puddle of rust on the garage floor the other day after a brief drive. It was leaking from the front of the muffler so I'm assuming it is starting to rust out anyway. I didn't crawl under the car to take a good look yet. I'm guessing though like most cars the stuff more forward is probably ok to keep as long as there aren't any holes started and it looks solid?
Thanks,
Bill
Thanks,
Bill
here is what I did. The LT1s have a different rear set up but utilize same mufflers.. Real happy with magna flow. DEEP rumble.
http://forums.corvetteforum.com/c4-t...e-1st-mod.html
I just had a Corsa cat-back system installed and I LOVE it. Great sound on acceleration but quiet at cruising speed, and NO DRONE, exactly as advertised. Got it from Autoplicity for just under $1200. Worth every dime.
My 96 I just recently purchased has the Borla system on it. It had so much drone it was almost unbearable. The best part is the system was no louder than the stock system. I had the resonator removed and replaced with a xpipe. Now it sounds great. Sorta deep and smooth with little to no drone.
Here is what I did with mine, I wanted a bit more muscular sound but not overly loud. Now it is only loud when I want it to be.
http://forums.corvetteforum.com/c4-g...ered-type.html
When I bought my 92, a previous owner had replaced the mufflers with a pair of Borlas.
The drone in the 35 to 45 mph range was horrendous.
I replaced everything from the block to the tips with a Stainless Works system.
Long tube (JetHot coated) headers, no cats, x-pipe, SW chambered mufflers, and polished square tips.
Not too loud, but she definitely sounds healthy.
I'm happy.
I'm happy.
Corsa is by far the best functioning and sounding exhaust i have heard on a corvette personally. Now i haven't heard it on a c4 only c5's but it really is drone free.
I'm happy.
I'm happy.
Yes I've not read much good about Borla's system. Many people have complained about the droning. Read a lot of good about Corsa, but they are even more expensive than Borla. I recently found this system NXT STEP PERFORMANCE Corvette C4 T304 Stainless Steel Axle Back System 1992 - 1996 they are going for $359 on Ebay. Wondering if anyone has any experience with them on a C4. The reviews for the C5 were good but the exhaust is a completely different configuration on the C5 so there is probably no correlation between the two in terms of sound or if they drone.
Thanks,
Bill
Thanks,
Bill
You should check into the OBX CatBack System. The construction is very good and the price is the lowest of them all. I really like mine on my 96'. A small amount of drone while going slow under load but from 45mph on up there just right. I'm not even sure I would call it a drone. It is just a deep growl when going up hill slowly. The polished Stainless looks great and my kit only cost $440,00 shipped.
Still happy with the muffler eliminators on the stock pipes.
The LT-1 rumbles like the big blocks of yesteryear.
New thought
I want to thank everyone for their replies so far. I'm looking at going a different route now. I'd like some opinions. I don't want to spend the money at this time to do a full cat back system. All of the axle back systems cut the pipes right at the Y or just ahead of it and your left with the look of a steel system going into a stainless system. I dont' think that would look very good?
Buddy of mine runs his own garage and works on all kinds of cars. Anyway he suggested the cheapest thing to try first is remove the resonators and just replace it with straight pipe. He has all the stuff to do it right. But I'm wondering will this make the car sound more aggressive? And most importantly am I going to get that dreaded drone at speed that many of you have seen with different exhaust systems? Anyone with any experience please feel free to chime in here. He said we could cut the pipes long enough so we can put them back on if it makes matters worse. Since mine is a 94 I don't have to worry about the computer check for my state's inspection. I don't think they can get me for inadequate exhaust? Since I will be leaving the stock mufflers on. I'm wondering though will I end up with a check engine light on all the time if I do this? Not sure how this is going to effect back pressure?
Thanks,
Bill
Thanks,
Bill
I'm looking at going a different route now. I'd like some opinions. I don't want to spend the money at this time to do a full cat back system. Buddy of mine runs his own garage and works on all kinds of cars. Anyway he suggested the cheapest thing to try first is remove the resonators and just replace it with straight pipe. He has all the stuff to do it right. Bill
Thanks,
Bill
Thanks,
Bill
I did the loud mufflers for a while. Eventually I didn't want to drive the car on long trips because it was just to loud and annoying. The setup I described above isn't for everyone but its a nice in between that I like. Basically loud when I want and almost factory silent the rest of the time.
