i wont bay Prothane Total Kit Corvette c4??
hi what about this product for my c4
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1733wt_948
What is the quality
What is the quality
I would only use the Polyurethane bushings for individual bushings that wear out- NOT every single one...they make a lot of noise and have to be lubricated to quiet them.
like maybe the two upper or lower control arm bushings. There are better ones made special for C4 upper arms, so I would not use those if you can afford the better ones.
St. Jude Donor '09-'10, '14
Come on be helpful. we were all new at some point. i don't know anything about them unfortunately or I would answer your question but Goldcylon says they're fine.
Wow, some people are just amazing. Guy was trying to get his point across the best he could. WTF is wrong with people anymore?
Both "Prothane" and "Energy Suspension" offer a quality product with their poly bushings. You will find that both companies have a loyal following of customers who swear by one brand over the other, but the truth is, both companies offer bushings that perform much better than the stock rubber pieces.
One thing you should keep in mind is that even though both are made of polyurethane - Energy Suspension's bushings tend to be noticeably more pliable (softer) than Prothane's bushings. This make's Energy's bushings easier to install and probably provide you with a slightly more comfortable ride. Of coarse, technically, because Prothane's bushings are stiffer, they will probably perform a bit better at the expense of a stiffer ride.
It's up to you. You can't go wrong either way, but if you're looking to improve handling without sacrificing too much comfort, Energy Suspension bushings might be the better choice. If you want maximum performance, go with Prothane.
Hope that helps.
Good luck and welcome to Corvette Forums!
Hope that helps.
When you were a noob were you also as rude as you now are? If you do not care for the questions asked on this forum then do not read them. Rude people will not be missed.
My car came with new energy suspension bushing and they are excellent, I've never driven on stock bushings but these are impressive to say the least.
I think you would be pleasantly suprised with them if you decide to go in that direction.
What is the quality
What is the quality
That's a good set of bushings, but like others said, urethane will ride rougher and make more noise than rubber. Make sure to use LOTS of silicone grease when you install them or they will squeak. It can get annoying. The squeak gets worse when it's cold outside.
The car will handle better with urethane than rubber as the suspension geometry stays more constant, but it's a trade off for a rough ride and noise.
Hope this helps.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Ok I'll say there is a bit more road noise....
Just turn up the tunes!!!
I too am quick to call out a troll, but I don't want to scare off legitimate new members. If someone is a troll, we'll know soon enough. And I damn sure don't want someone getting scared off by a simple language barrier that's easily overcome by all parties.
We're all joined worldwide by our common interest of these cars.
Many of them are laying low....
I didnt know there was a language barrier involved. I looked up his profile and it didnt list where he is from.
If in fact there is a language barrier, then I am truly sorry.
Yep, he's from Kuwait. He's posted pics of his (very sharp) C4 complete with Kuwaiti tags on front.
