Door Alignment
Door Alignment
I did a body off on my 75 and ended up replacng the rear clip with an ACI one piece for a 69-73. I put my doors back and the gaps look pretty good but on the back lower corner the door sits in about 1/2". The rear clip is tight against the jam and I don't really see what could have changed to cause this. Has anyone else ran into this? How do I fix it. Thanks
Look in Stinger's "Rookie Restoration" thread in the General section... Once in the thread, search for door or door alignment and it should take you to a page where it shows where he fixed his problem (with Mike D's help) which is similar to yours... This should fix your issue...
Here's the link:
http://forums.corvetteforum.com/c3-g...post1572837725
Rogman
Here's the link:
Rogman
