Wheel/Tire combo opinions
I am looking to get some 17x8 inch wheels and tires. I have three in mind. The Torq Thrust M in black with a polished lip, the Torq Thrust 2.1 Chrome and the chrome SLP ZR1 style 5 spokes. I suck at photoshop or I would try to do what some guys do and put them on my car in pics to see how they look. I am leaning toward the Torq Thrust M black, since I think it would look good with my present 2 tone paint, but I welcome dissenters. Second question is what is the best size tire for a 17x8 wheel on a C3 with no mods needed for fit. Thanks for the help. Momma said OK so I need to act before she changes her mind. Jeff
PS I looked in the wheel and tire section, but there is no C3 filter so it is hard to sift through the questions, So I thought I would ask here, even though I am sure this has all been hashed out. Thanks!
I agree that a dark wheel might look better with your paint scheme. I love chrome wheels but only on dark painted cars. As far as the size. I am no expert at all but I seem to recall a 225/50/17 being a tire size that will fir a 17x8 rim and get very close to stock overall diameter so the speedometer stays accurate. I am not for sure though so maybe another member has a better memory than this old fellow.
I believe 245/45/17, look at www.tirerack.com they give an optional 17" wheel size and tire.
OK....will a 4.5 inch backspace wheel in 17x8 need a spacer to look right? Will I need to go to a 17x7 to get 4 inch if needed? I searched every thread on here for hours and all I want is a 17x8 wheel and tire combo that will work, is there one?? I like the black machine lipped torq thrust M wheels, but they only come in 4.5 inch backspace. Anybody here have a 4.5 inch wheel on a car without spacers that has a pic or an opinion?? HELP!!
Actually it's a 255/50-17 that is 27" tall which is the same height as the stock tire.
As far as the 4.5" backspace goes there are lots of cars on here running large diameter (17s or 18s) with that backspace and it's look fine.
Do a search on here and the C3 general forum using "17s" there is literally hours of reading and several pictures.
I have the SLP wheels with 245/45/17 tires.
They are a close fit.
I had to relocate the E Brake cables and turn a carter keys for two wheels so it wouldn't rub.
I like the look and feel of this set up.
If you want to go wider I'd go with an 18 or 19 inch rim for more clearance
around the ball joints, tie rods and such.
Mine is very close.
Sorry no pictures of the fit.
Mine is very close.
I think I am going with COY's 17x8 inch BlackChrome C-5 wheels (not c-5 Corvette) with 4 inch backspacing. I will put 255-45-17 inch tires on them.
You can get the TT 2.1 in 17x8 with 4.1 bs. 255/50, 255/45 or 245/45 will probably work. 4.25 bs might not work with the 255's in the rear without tying the park brake cable to the trailing arm and /or possibly relocating the bracket. Of course you could use a thin spacer if needed.
I put 255/50 on the rear with no issues and 245/45 on the front. I am not particulary worried about rotating as they will dry rot before I put 5000 miles on them.
1 Post
1975 with TT M's 17x8 245/45 front 255/50 rear. No spacers, no alterations
[IMG] http://img169.imageshack.us/img169/816/imgp1001xk4.jpg [IMG/]
Yea, I think I am going to the TT 2.1's from Wheels for less. You can get them with tires already mounted and free shipping at a pretty decent price. The only reason I said 255's was because of the height, they should be 27 like the stockers and fill the fender nicely. I don't mind moving the Ebrake bracket at all, I never use it, I could take it off(but won't) Are those the new tires in your avitar? Car looks great!
Go with 18x8 Torq Thrust M with 255-45-18. Same diameter and width as the stock 255-60-15. The 18" rim with 4.5 BS will clear the lower ball joint in front since it will be inside the wheel and the rear parking brake cable bracket will also be inside the wheel and won't touch. You can go with a wider tire and wheel on the back if you do relocate the cable bracket. The 18's look great.
