Object on fuel line before carb?
You can buy a high pressure gasoline hose that is rated for fuel injection (40 -50 psi) at a good industrial hose house. (Around me, that's Industrial Rubber in Elizabeth, NJ 908-351-1550 ) You need to be really careful with any gasoline. Really careful.
I knew a real vette owner would appear and call everybody else "bubba" thanks. I probably wont drive mine anymore because im afraid you will ride into town up and really show me up!
The problem with the braided stuff is that the ss braids just cover rubber hose. If that rubber hose starts to fail ( maybe because of the new ethanol) you won't see it under all that ss braid. The problem with using race style hose is that the race guys know to replace it often. Its not really made for the many miles of a driver. If you use that stuff just be sure to inspect it often. I used very expensive aeroquip socketless hose and connections on my last project. I was VERY surprised to see fine hair cracks in the outer hose after just two seasons. Take whatever risk you feel comfortable with your fuel supply but the truth is that hard plumbed metal line is best in almost all applications where safety is priority.....jmo.
I have no idea how you came up with this from what I posted. Sorry, but I was not directing any of my comments to you personally.
I have braided synthetic inner fuel lines with AN fittings. My race bikes all had the same thing and they were alcohol injected. But I agree on plain rubber it has no place sitting atop anything that can cause ignition....
Holley, Edelbrock and the other major hitters sell Carb to hose/pump to hose fittings. When the proper rated hose and clamps are installed correctly there is nothing wrong, unsafe or dangerous with this type of installation.
Just a random posting off the Internet.
"I finally got through on tech support at Russell (Edelbrock) today, and spoke to a helpful tech. He said they may last as few as 3-5 years with the seasonal cycles of racing and sitting for months. He recommended trying their new Pro Classic Black hoses, which are a black nylon braid but use the same AN fittings as stainless but for less money, and they have been selling it for 4 years and have not heard of a failure yet, or their Pro Race series which has 1 more barrier in it (but is more expensive)."
I would not put a race style hose....or any rubber hose near my heat sources and just drive off into the sunset without looking back. I'd be checking them a few times a season. Jmo
I heard of racers pulling cars out of storage and finding the hoses went from ok last season to leaking like a sieve the next.
#33
FYI. Mine is exactly as you describe right now, but I am installing a hard line and filter this fall when I have the intake off for a swap to the rpm airgap.
#35
Here is a nice, easy, cheap way of doing it using brake tube with 45° flares. Filters with an fittings are also readily available and easy to flare the tube to fit (37°).
Here is the link to the thread.
http://forums.corvetteforum.com/c3-t...ol-review.html
There is some very capable flex hose out there, but I don't see the need for for the expense of the hose and an fittings.
Modern fi engines all use a braided flex from to frame to engine as the pump is in the tank and fuel runs a much higher pressure. I have a truck that has a 15+ year oem crimped hose assembly with no leaks.
#36
If you have an in-line electric pump, you will need a flex hose somewhere between the pump and the engine. Just make sure it isn't near the engine (put it just after the pump on the frame rail). Pressurized fuel spraying on your exhaust manifold, etc. is not good for your car or for you. Use a good quality fuel line with braided metal jacket. And check it every now and then for any wear/tear or damage.
#37
It doesn't take much time or effort to go have a steel fuel line fabricated for your specific configuration. This was the first thing I did after installing my Holley. Safety and "Peace of Mind". If I were to use anything else it would be placed away from the exhaust/headers or away from the top of the engine. I'm sure there are some acceptable alternatives.
#38
St. Jude Donor '11
Whats wrong with using just the carb. filter? My 36 yr.old car hasn't given me problems. I plan on just replacing it when I rebuild my carb. shortly. Do the moded engines need less restriction? Just askin.
#40
