Installing new master cylinder and have a question
My 69 does not have power brakes. Is there anything I need to do special to remove the master cylinder, besides drain it as well as I can first?
A website I was at said to disconnect the master cylinder linkage from the brake pedal under the dash. I'm not sure I understand that and have not seen it mentioned anywhere else.
Before I begin, can anyone offer some guidance?
No need to go under the dash. Remove the 2 tubes at the M/C then the 2 mounting nuts and out it comes. If you bench bleed the new M/C before install, you MAY not need to system bleed at all. At a minimum, the system bleed will go much easier with the M/C pre-bled.
Gary
Bench bleed setup.
Gary
Bench bleed setup.
Gary
Bench bleed setup.
Gary
Bench bleed setup.
Gary
http://forums.corvetteforum.com/c3-t...-cylinder.html
You are pushing on the piston. Check this thread (link below) out as it has some more pics of the inside of a M/C. It will move without fluid, if you push hard enough with the screw driver.
Gary
Gary
Thanks, I was worried about pushing too hard
