Seriously considering removal of side pipes!! :-(
LOL!!!!! Thanks guys there are a lot of wide range emotions here.... I am going to drive it a little more and see. If it were a coupe it might not be as bad but being a vert it is really loud. I may look into the heat sheild option as well. The pipes will peel the skin right off your leg after only a few minutes of run time.
I do like travis' setup though. The only way I would swap is if I can get enough out of selling the current system to cover at least the cost of the headers and the muflers.
Wade
Wade
Received 1,327 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
Here's a possibility you might consider: Leave the sidepipes loud, but reduce your RPMs on road trips by adding an overdrive transmission.
I did that on my '65 BB with sidepipes. Before, I was turning 3800 RPMs at highway speeds and the roar of the sidepipes would give me a headache after about an hour.
After installing the 5-speed transmission, I'm turning about 2,000 RPMs at highway speed. BIG difference in comfort factor!
And, yes, now I can hear the radio again.
Cruise-In VII Veteran
St. Jude Donor '06
Thanks guys but I already did the TKO600 upgrade. In 5th gear it does help a lot. However, I live in a rural area and rarely see 5th gear. I have been looking at other inserts outside of my JCL spiral baffles. Has anyone done a sound and power comparison?
Wade
Wade
I am having the same thoughts on my 72 coupe. I took the under car exh off and that made a big difference to the heat inside the car, which is why I wanted to try the side exhaust in the first place but I liked the sound of the pipes out the back a lot better. My car is actually easier on the ears with the windows down, tops off and the back window out, if its all closed up then I get the drone and that is more annoying. I have a 4l80e overdrive trans and tach about 2200 at 75 mph, and that seems to be the worst speed for the noise. I was toying with the idea of putting the under car exh back on and running some of those "Y" pipe valves and hooking both systems up...out the back for trips, out the side for town. O and that myth about cars being so quiet with turbos on that you probably wont have to run mufflers.... not true.
Hello
I have a 68 and wanted the side pipe sound but not the heat - I just put on the N-11 off road chamber pipes under the car by Mid america- They sound great when taking off and are so quite at crusing speed that you can talk on a cell phone and hear the radio.
Wade,
Why don't you get your trusty welder and weld the holes in the spirals shut. That will reduce your noise level, and forget teh notion that welding the holes shut will choke the HP. Losing 3 hp is not choking the engine....
GDaina,
I think I am going to try this again and see if I notice a difference or if it was just in my head because the pipes were quieter. So with the JCL's ran in the stick config which is center pipe closed I will lose only 3 hp?
Wade
My side pipes were too loud too.. chambered straight thru's.. installed by previous owner. it was a big project... buy matching paint base coat clear coat, and paint a new back panel for the rear exhaust exit, new tips, new bezels, new rockers on the side, screw kits, and the entire front to back aluminized pipe and muffler set.. cost me about a week of labor/chasing parts.. all about 950$.. sold my side pipes for 500.. some of the best money I spent on my car.. nice and quiet for cruisin.. I say go for it...
Before and after Pics...
I removed my sidepipes, all inserts to loud, tried spirals, max flows, except for the reverse flow, which choked the engine. I wanted to listen to the radio so they had to go
#37
No, it was somebody else with a HIGH HP application.. I believe that it was a big block and he had something like a 30 - 40 HP difference.. At low HP applications (below 400 HP), the difference might be smaller but at high HP applications, the cap on the baffles really costs a lot of power..
#38
#39
I think it was a 75 hp difference unplugged actually.
I unplugged mine but haven't driven it yet. It will probably be too loud, but I have a plan...
I think I can extend the tube of the spiral baffle out the back and make some plugs I can undue by hand through the tip of the sidepipe outlets.
