chassis stiffening on c3 'vert
Hi guys, my vette is turning into a pro tourer, anyone used any aftermarket braces or any tips on where to stiffen up the chassis on my '71 vert, i've got the front strut brace (havent installed it yet), also interested in rollcages, anyone got one in a 'vert? does it help much, i'm guessing you cant get the hood up once its in place, or can you? would an unboltable one be any use, it has been known to rain in England! thanks. Aaron
If you do not want a roll bar or cage I put in a Shark Bar on my vert. It really stiffened up the body. I use to have all kinds of shakes and rattles before the bar. Now it is very tight. Also gave me a place for my 5 point harness. http://www.vetteworksonline.com/6873...ness%20bar.htm
You can get it with or without hoops.
I know how much difference the spreader bar made in my car. Just reading Gordons review of the sharkbar makes me want to get one for my vette.
So many good ideas on this forum. Once you think you have almost reached a finishing point, you still find there are several things you might like to add. Thanks for the pic Gordon.
One question Gordon, would the bar interfere with my seat belts. I have the camaro belts coming through the opening in the trim.
Crud! Not exactly what I was wanting to hear. I wonder if the rear mount with the heim could be modified to move heim over toward the fender. You could move the heim on the other side of the mount on the sharkbar, toward the outside of the car. Cut the tab off and move the tab on the bracket toward the outside of the car, toward the fender also. This may give more room for the camaro seat belts. I hope this makes sense.
If you're still cookoo over the sharkbar then it doesn't matter much where you mount that rear support strut with the heim joint b/c that is there to prevent any forward movement of the sharkbar if in the event your 5pt harness is put into use and pulls that bar forward. It may slightly help against a twisting motion in the body but the rear support struts are only mounted to the fiberglass body so there isn't much strength there in a mounting surface, its there to prevent pulling force. Since you won't be using the sharkbar for a harness you won't be pulling the bar anywhere so the rear support bar isn't really needed, or you can mount it whatever way you want, just know that if you are to use the sharkbar to mount a 5pt harness in the future that you do mount that rear support strut securely and at the best angle that doesn't jeapoardize the functionality of the sharkbars stability under significant pull forces forward.
Just my 2 cents.
Spreader bar is a no-brainer worth adding to any C3, where possible. Additionally, I'd make sure the body mounts are solid and install solid engine mounts. Further, IMHO some extra bracing in the floor plane of the chassis is a good idea.
FWIW, it should be noted that going larger on "sway" bars, while increasing anti-roll stiffness, does not stiffen the chassis itself.
mine is a Vert and I have a cage. The cage is designed so that the soft top opens and closed perfectly and the cage is NHRA legal and certified to 8.50
5 point really holds you firm in the seat. I can barely roll up the window or reach around the steering wheel to turn the car off when I am snugged down by the 5 point. Just the way I want it. You don't move an inch on the autoX or the strip.
Thanks guys, loads of great info, i think i'm leaning towards a 6 point cage with removable bars, i've just ordered a TKO 600RR and ali prop so the cage will have to wait a while!
p.s- the day i ordered the box i heard a news report that said the pound had fallen to its lowest level against the doller for 25 years! Dooooh!
Sharkbar 1980
does anyone have a pic of the sharkbar installed in a 80-82 vett? i am ordering it today for my 80 project car as a birthday present to myself,i am wondering if it can be installed first,or if it is a better idea to ahve 82 c.e rear pop up window installed first?it is a 1980 and the hinges on the top of the glass have to be mounted to the car,i am not sure if on the 82 c.e this was riveted in?i also have to have something made to mount the window struts,where windoe struts mount to the car it looks liks it is in same location as sharkbar,speeddirect lists the sharkbar for 78-80-81-82
Dan
Vetteworks
253-223-4968
This four point roll bar from Autopower really helped to stiffen my chassis, but its's welded in, not bolt in. I had them custom make a shorter version for me so that it could fit in the C3 behind the seats. I think the one in the catologue is for C2s.
Bee Jay
Bee Jay
And how much was it to install, in your neck of the woods?
