6 Point Cage photos
That is Very good looking, The pic reminded me of a Friend who had a Well modded 69 vert. His car was popular on the forums.
Outstanding Vette..Got anymore details??We love details...
Yes, I mistyped about cage vs. bar.
It was shop fabricated, and the chassis is much stiffer. Launches better and handles turns better. The bar was difficult to get any higher, as the it would change the angle of the 2 rear supporting bars such that the bar would move higher and more forward to an improper spot. At least that's what they told me.
main hoop is monted at the beginning of the rear frame and is mounted straight, the bar also can't be too high as the rear supporting bars wouldn't have enough space.. However, if you have the main hoop tilted slightly, it works out a lot better..
$1100.
Was $100 a point (mild steel) ($200 for moly), plus $300 for the swingarms, plus materials, and some welded gusset replacements, labor (take out and reinstall seats, rugs, etc) and paint.
Did a very neat welding job.
Sounds good Highhat. Thanks for showing it.
That really looks clean and the fit looks perfect!
Has anyone tried one of the pre made units from these guys? I'm sure it's not as good as a hand built one, but I wonder if the fit is close or not.
http://autoweldchassis.com/
I paid $750 for the 6-point bar in chromoly and the swing out...
I like the look but it seems like the crossover could go back further. I realize that to anchor to the side beams/floor requires it to be where it is, and I like the tilted option others have mentioned. I thought that I saw others that went down to the curved section of chassis rail. Is that any less or more safe/strong/stiff?
My real concern is with how close the door bars are to you and your potential passenger. I know I fit up against the door in my 75 and I'm a small fella. I take it this is a street car that sees track duty? I'd be happier with the driver door opened up and a more "nascar" style driver's side arrangement where they go into the door for extra crush room.
