How to dismantle my '69 T tops?
We are just beginning the project but one of the first things I noticed is the rattle inside the T-Tops. It sounds like there are several small pieces of gravel inside the tops. The inner panel popped off easily enough but the gravel is further inside. There are a few bolts like the ones holding the inner chrome tabs but they don't loosen anything. I need to separate the two halves or at least create an opening to shake the gravel out. Has anyone done this before>
Received 1,139 Likes
I was able to shake everything out through the existing holes. I don't remember now, but they have to be the remnants of the rivets holding the nylon fasteners. I don't recall them rattling around while driving but these are definitely one more thing that could.
A10pilot (07-31-2023)
Highway Man
If someone ever replaced the weather-stripping, when you remove the old weather-stripping, some of the old nylon pushpins can break off and fall inside the T-Top channel and will rattle around and make noise.
As well, the riveted nut holders that secure the weather-stripping channel, sometimes rusts away and the pieces fall in the T-Top channel and will rattle around and make noise.
What I've read on CF as well as in this Motortrend article below is that you drill a hole, remove all the pieces and then put in a plug, its brilliant!
https://www.motortrend.com/features/...orvette-t-top/
Cheers,
Richard
Cheers,
Richard
Where can I obtain the bolts that are used securing the tab that engages the T-tops to the center post. When they restored my 69 T-tops they used washers to shim the Tab/bayonet to help level the T-top to rear section of the roof. I need to use longer bolts to allow me to shim the T-top a little higher to level it out with the rear roof section. This will also allow me to address the rattle of these tops also.
v/r
Mike P.
v/r
Mike P.
Highway Man
Are your nylon inserts warn that the tabs slide into? These are available and easy to replace.
I give you credit though… That’s dedication and perseverance! Doesn’t surprise me though, I’ve seen your restoration efforts. Always first class work!
Regards,
Stan Falenski
