Quickjack and jack stands
For those out there with a Quickjack...... do you put a couple jack stands under the car in addition to the Quickjack just for that extra level of safety? If you do, where do you put them since the side rails are taken?
Popular Reply
05-30-2022, 11:20 AM
Dementer sole survivor
Received 6,341 Likes
2016 C3 of Year Finalist
no I just make sure the quick jack is in the locked position and lowered onto the stop
The following 7 users liked this post by Rescue Rogers:
210ken (06-02-2022),
Barry's70LT1 (05-30-2022),
Bikespace (05-30-2022),
Hunt4Fun (05-30-2022),
Joebrick (05-30-2022),
and 2 others liked this post.
sleepchamber (05-31-2022)
No x3
Received 3,149 Likes
I'll be the outcast here. If I'm going to have it in the air for a long time (winter work type of thing) I put a set under the front by the swaybar mounts but just to sort of take some of the weight so it's not hanging the entire front of the car from the door ahead. I've got a set of rubber pads that sit on top of the stands and all I do is raise the lift all the way and before I let it down onto the stops I put the stands in place and when it gets lowered to the stop it touches the pads and compresses the rubber. Measured difference in height at the bumper point is minimal but I somehow feel like it's helping take some stress off of the frame / body / firewall joint.
Not for safety concern at all
M
M
The following 3 users liked this post by ThomasR:
interpon (06-01-2022)
Thanks all for the feedback on this.
A completely different Quickjack item I found that could be of help is the issue of not being able to reconnect hoses at the pump connections. I had this issue and couldn't get the hoses back on....just wouldn't push back on at the pump side. Found that with the pump plugged in and pressing "down" while pushing on the quick connects....they go right on. Hope this helps somebody.
kanvasman (06-01-2022)
what happens is when you let it down, if you do not let it drop all the way (also why the compessed air in cylinder pushes down) and release pressure, it is very difficult to unhook.
Of course mine stay hooked up and under car
Joebrick (06-01-2022)
