1971 Journey
Old 02-12-2019, 02:54 PM
  #1421
CraigH
CraigH's Avatar
Originally Posted by Primoz
Craig nice work. I suggest good quality wax or sealant for that front apron so you can protect it as best as you can.
Craig can you please look at the front driver side at the radiator support if there are any wires bolted to the support for ground?
I have some wires there that looks like they are detached and I don't know where they should go.
i will grab a picture this morning. There is a ground point on the drivers side of the radiator support.
Primoz (02-12-2019)
Old 02-13-2019, 12:21 AM
  #1422
CraigH
CraigH's Avatar
Here is the earthing point.
The following 2 users liked this post by CraigH:
OldCarBum (02-13-2019), Primoz (02-13-2019)
Old 02-19-2019, 11:18 PM
  #1423
CraigH
CraigH's Avatar
Started doing some touch on the engine bay, headlight area and front apron so i can start re assembling things.
Primoz (02-19-2019)
Old 02-19-2019, 11:19 PM
  #1424
CraigH
CraigH's Avatar
Media blasted some of the headlight mechanism parts ready for paint.
Metalhead140 (02-20-2019)
Old 02-19-2019, 11:24 PM
  #1425
CraigH
CraigH's Avatar
While I am putting Vette back together i thought I would get the 15' rims media blasted and powder coated.
Don't use them that much but thought they deserved some treatment.
Started by getting them stripped of tyres etc.
What do i find. !!!!
They are all 15x7" rims.
Correct offsets but an aftermarket set.
The spare was a Chevy rim but not for a corvette and also 15x7"
Luckily I had another Vette set i was given by a friend who upgraded his rims.
Got them stripped off and now I will have 4 15x8" rims for the Vette and a spare that is 15x7"
All at the powder coater to get done now.
Old 02-19-2019, 11:28 PM
  #1426
caskiguy
Support Corvetteforum!
caskiguy's Avatar
Never hurts to have a bit of Luck show up now and again.
Old 02-20-2019, 02:46 PM
  #1427
CraigH
CraigH's Avatar
Yes very lucky years back i grabbed the set of rims that were destined for the trash.
also lucky I checked my rims for numbers etc once they were stripped and found they were wrong.
Old 02-22-2019, 02:53 AM
  #1428
CraigH
CraigH's Avatar
A bit of progress on the headlight mechanism parts.
Should get more time next week so hope to have better progress.
Primoz (02-22-2019)
Old 02-22-2019, 10:18 AM
  #1429
Primoz
Primoz's Avatar
2017 C3 of Year Finalist
Nice work Craig. I finally "beat" you on one thing. I did this couple of years ago on my 71. Be aware when you screw on the headlight actuators on how many turns you will screw them on, because if you make a couple of rounds too much your headlights won't rise enough and you will have problems adjusting the beam of the headlights and also mounting the headlight surround. And of course they won't be aligned with the rest of the body when they are retracted.
Just to warn you a bit. BTW how is your headlight support bar? Is it in good shape?
Old 02-22-2019, 03:24 PM
  #1430
CraigH
CraigH's Avatar
Thanks for the tip Primoz. I will measure the turns from the existing actuators, if I have not already removed the adaptor from the shaft.
my headlight support bar is fairly good condition.
Primoz (02-22-2019)
Old 03-06-2019, 05:33 AM
  #1431
CraigH
CraigH's Avatar
Got my rims back from powder coater today.
Very happy with results
Primoz (03-06-2019)
Old 03-06-2019, 12:45 PM
  #1432
Primoz
Primoz's Avatar
Wow Craig! Nice wheels!
Old 03-10-2019, 09:56 PM
  #1433
Skootter14
Skootter14's Avatar
just came across this thread, very impressive. Your work along with the detail in your thread is great! Thanks for doing this. It can def help those of us starting out see how involved some aspects can be!
CraigH (03-23-2019)
Old 04-13-2019, 01:58 AM
  #1434
CraigH
CraigH's Avatar
Started to do some more work for reassembly.
I cleaned up inside the front guards, replaced some of the missing seals, seam sealed it all then gave them a spray with bed-liner.
Also fitted the front side markers.
PainfullySlow (04-30-2019)
Old 04-13-2019, 01:59 AM
  #1435
CraigH
CraigH's Avatar
Started putting the front harness back on header bar.
Primoz (04-13-2019)
Old 04-13-2019, 02:01 AM
  #1436
CraigH
CraigH's Avatar
Headlight mechanisms so far.
PainfullySlow (04-30-2019), Primoz (04-13-2019)
Old 04-13-2019, 06:52 AM
  #1437
SB64
SB64's Avatar
All looks great H, touchup work may be coming to an end? Really makes the beaitiful paint color pop! WOW
RVZIO
To 1971 Journey
Old 04-13-2019, 08:01 AM
  #1438
AllC34Me
Senior Member
AllC34Me's Avatar
Received 2,031 Likes on 1,103 Posts
St. Jude Donor '10
I appreciate the pictures, so thank you for posting. I am impressed with your paper prep for painting, and realize I need to do a better job of this myself. Thanks for the help.
David Howard
AllVettes4Me
Old 04-13-2019, 10:05 AM
  #1439
OldCarBum
OldCarBum's Avatar
Received 4,696 Likes on 2,936 Posts
David Howard
AllVettes4Me
A tip I’ve noticed on the forum in past threads that looks to work better than paper, is wrapping with aluminum foil.
Old 04-13-2019, 05:01 PM
  #1440
CraigH
CraigH's Avatar
yes aluminium foil works great for irregular shapes. I used it for the ends of the swaybar and wiring etc
Quick Reply: 1971 Journey
